I use a program called Miro to download videos from Youtube. When I find a video that I like/need I always choose the highest quality and then begin the download process with Miro. I am not sure, however, if it is downloading at the highest quality or the lowest quality. Is there any way to check for this? to change this?
I use an add-on for firefox and chrome called Youtube HD Suite that automatically opens the highest quality video and shows all the files types that are available and if you right click on the file that you want, you are given an option to download the file.
Try: http://www.bestvideodownloader.com/support
You can select your prefer resolution/quality (audio & video) to download any video.
Claudio
split screen when playing downloaded 3d from youtube
By edong in forum Off topicReplies: 3Last Post: 5th Mar 2012, 18:21 -
youtube downloaded video audio sync problem
By halekon in forum DVD RippingReplies: 0Last Post: 13th Jun 2010, 21:52 -
How to get a quality DVD video from a downloaded 'flv format (Real Player)
By elaway in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 20:39 -
Why won't YouTube convert a video that was downloaded from YouTube?
By brassplyer in forum Video Streaming DownloadingReplies: 0Last Post: 5th Dec 2008, 05:47 -
why can´t find FLVs downloaded by means YOUTUBE on IE7 temp files folder ?
By RonWolpa in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2007, 08:16
