  1. Hi,
    I am looking tools which shows the .mov file timecode track information.(tmcd atom).
    What is my thought in .mov files there is usually video audio and a timecode track. The timecode track gives a start time value. This is the timecode value for first video frame and rest of the video frame timecode, calculate with respect to time scale value and duration from the corresponding track header.
    Please share a tool to find the start time of .mov file and correct me if any difference in my thought.
    Dave
  2. ffmbc (and ffmpeg?) now display the timecode. It cannot change it, and there are bugs when trying to copy the data track to a new file, but it does display it. I couldn't yet test to see if it's really correct.
  3. I use ffprobe to understand the anatomy of the file.
    ffprobe.exe -show_streams test.mov will give the following info about the timecode track
    [STREAM]
    index=5
    codec_name=unknown
    codec_long_name=unknown
    profile=unknown
    codec_type=data
    codec_time_base=1/25
    codec_tag_string=tmcd
    codec_tag=0x64636d74
    id=N/A
    r_frame_rate=0/0
    avg_frame_rate=0/0
    time_base=1/25
    start_time=0.000000
    duration=52.640000
    bit_rate=N/A
    nb_frames=1
    nb_read_frames=N/A
    nb_read_packets=N/A
    TAG:language=eng
    TAG:handler_name=Apple Alias Data Handler
    TAG:timecode=09:59:40:00
    [/STREAM]
    ffprobe.exe -show_packets test.mov
    [PACKET]
    codec_type=data
    stream_index=5
    pts=0
    pts_time=0.000000
    dts=0
    dts_time=0.000000
    duration=1316
    duration_time=52.640000
    convergence_duration=N/A
    convergence_duration_time=N/A
    size=4
    pos=349757537
    flags=K
    [/PACKET]
    Can anybody clarify following questions ?
    The issue is when i check the pos = 349757537 in the file i got the value 00 0D B9 AC 00....[Byte value in the file]
    The TAG:timecode=09:59:40:00 how can i match this value to the file data.[I suspect endianness change?]
    Is there any different meaning for TAG:timecode.?
    How can find TAG:timecode value from the file? or TAG:timecode is derived from any other values?
    Dave
  4. Quicktime Pro gives you the option to see the timecode track if you click the counter. Not sure about the free version.
    What are you actually hoping to accomplish?
  5. I tried to read the start time code from the file.
    In byte format as it is present in the bit stream.
    Regards
    Dave
