Hello everyone, I have some questions about B-frames in x264 and H.264 encoding.
1) Does "B-Frame as Reference Frames" feature improve output video quality? (I mean, should I enable or disable it?)
2) In "Sorenson Squeeze" software, there is "Number of B-frames" range of 0 to 100 (in x264 codec), so I can adjust any value of B-frames from 0 to 100. So, please tell me should I adjust the value 100 to result better quality? (Or, which value should be optimal for me? because I realy don't care about encoding speed, I just need HIGHEST QUALITY)
3) Should "pyramid B-frame" feature work, if "Number of B-frames" value is more than 3 ?
thanks.........
Results 1 to 1 of 1
x264 encoding options (NOT H.264)
By LeoKac in forum Video ConversionReplies: 2Last Post: 7th May 2012, 16:53 -
mencoder x264 vs libavcodec for h.264 encoding
By chconnor in forum Video ConversionReplies: 0Last Post: 2nd Mar 2011, 15:31 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
Encoding a video with x264 from multiple files
By Virnec in forum LinuxReplies: 2Last Post: 22nd Feb 2010, 16:56 -
Best CPU chart for x264 HD Video Encoding Performance
By INFRATOM in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Feb 2009, 22:55
