I'm converting a 400x300 .flv to mpeg4 h.264 and am getting some strange behavior from the WinFF presets. On the video tab, I set size to 720x480 and aspect ratio to 4:3. (WinFF version 1.4.2)
The -crf 15.0 preset works as it's supposed to...
but the -crf 35.0 preset produced a video without the specified 4:3 aspect ratio. I've checked the properties in Media Player Classic and the aspect ratio info is missing.
I also created my own preset by changing the -crf number to 25.0, leaving all other parameters the same. It produces a file with audio, but the video is a black screen, and the aspect ratio is incorrect here as well. BTW, if I change size to 640x480 the aspect ratio of course looks correct but "4:3" doesn't show in properties and the video is still blank
Why is the -crf 15.0 preset producing the video with the specified settings but the other presets aren't?
Can you post the full ffmpeg command line?
You could also try another ffmpeg frontend like hybrid or xmedia recode. -
These are the 3 command lines. But I'm adding resolution and aspect ratio in the video tab.
-crf 15.0 -vcodec libx264 -acodec libfaac -ar 48000 -b:a 192k -coder 1 -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me_method hex -subq 6 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -b_strategy 1 -qcomp 0.6 -qmin 0 -qmax 69 -qdiff 4 -bf 8 -refs 16 -direct-pred 3 -trellis 2 -wpredp 2 -rc_lookahead 60 -threads 0
-crf 35.0 -vcodec libx264 -acodec libfaac -ar 48000 -b:a 128k -coder 1 -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me_method hex -subq 6 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -b_strategy 1 -qcomp 0.6 -qmin 0 -qmax 69 -qdiff 4 -bf 3 -refs 5 -direct-pred 3 -trellis 1 -wpredp 2 -rc_lookahead 50 -threads 0
-crf 25.0 -vcodec libx264 -acodec libfaac -ar 48000 -b:a 160k -coder 1 -flags +loop -cmp +chroma -partitions +parti4x4+partp8x8+partb8x8 -me_method hex -subq 6 -me_range 16 -g 250 -keyint_min 25 -sc_threshold 40 -i_qfactor 0.71 -b_strategy 1 -qcomp 0.6 -qmin 0 -qmax 69 -qdiff 4 -bf 3 -refs 8 -direct-pred 3 -trellis 2 -wpredp 2 -rc_lookahead 60 -threads 0
"Pass Thru" presets for WinFF.
By bat999 in forum User guidesReplies: 6Last Post: 14th Aug 2014, 17:33 -
Importing many presets in WinFF
By Klagar in forum Video ConversionReplies: 6Last Post: 28th Sep 2010, 16:44 -
Big proble here! Camcorder is producing a strange noise
By Fidla in forum Newbie / General discussionsReplies: 10Last Post: 8th Sep 2010, 09:46 -
x264 Producing Strange Artifacts in Fields of Light Color
By WhoThatBe in forum DVD RippingReplies: 5Last Post: 13th Mar 2009, 16:53 -
SVN ffmpeg now supports iTunes friendly muxer: WinFF presets
By GMaq in forum LinuxReplies: 0Last Post: 26th Oct 2008, 15:32
