There is so much to read on VHS-->digital converting that my head hurts.The tapes I am planning(hope) to capture are S-VHS that are about 5-6yrs old and VHS-C are about 10yrs. I have some spare parts from a custom PC I build 4yrs ago:
I also have a Panasonic-PV-V4525S VCR and Hauppauge WinTV-HVR-2250. I am planning to store the videos on hard drives to be played back on the computer/streaming. Finding an old 80's/90's VCR and ATI capture card are hard to find, those options are not feasible. Also the TBC I'm looking to get is AV Toolbox AVT-8710 Multi-Standard Time Base Corrector. Would the this specific hardware be able to do job?
- Intel DG31PR
- Intel core2duo E8400 3.0ghz
- 2GB RAM(upgradeable 4GB)
- OS: either Windows XP(32 bit)/7(32/64 bit)
Sincerely,
fluffyshy
ATI capture cards are indeed difficult to find, although the later digital cards -- 600, 650, etc. -- are decent. But there are so many VHS and S-VHS VCR's circa mid-1990's from Panasonic and others, I don't see how you missed them (I just bought two 1995/1996 Pannies during the past month, and saw several a couple of months ago).
The AVT-8710 won't do that much for the kind of tapes you mention. It's a full-frame tbc. The big problem with tapes is line timing problems, not usually frame timing. A line-level tbc would serve you better. They cost plenty. But you can get by cheaply, as many do, by using a vintage 2002-2005 Toshiba or Panasonic DVD recorder as a line tbc pass-thru device.
Examples of playback problems, with full-frame tbc and two pass-thru line tbc devices here:
https://forum.videohelp.com/threads/331681-s-video-artifacts?p=2141386&viewfull=1#post2141386
Old tapes and copy protection, here:
https://forum.videohelp.com/threads/331681-s-video-artifacts?p=2141384&viewfull=1#post2141384
A whole thread full of really thorough, picky, techy tests, charts, videos, webcam usage, etc:
https://forum.videohelp.com/threads/319420-Who-uses-a-DVD-recorder-as-a-line-TBC-and-wh...591&viewfull=1Last edited by sanlyn; 22nd Mar 2014 at 08:16.
Your PC specs are fine. Go with XP 32-bit for the OS since alot of the legacy hardware works great with XP, plus its stable. Alot of the older ATI cards were optimized for XP since quality and capture was more important in that time than it is now.
You can try to find a SVHS VCR with the built-in TBC.....there's one on ebay right now for $250, and features line TBC and DNR which will help to cleanup the tapes: JVC-HR S7800U I trust the seller of this unit because I bought a broadcast deck and another JVC unit from him and had no problems.
An external TBC is useful for doing away with the MV on the commercial tapes. It only stabilizes the signal for a clean capture, it does not clean up the video. And there may be some cases where you may not need the external TBC, just depending on the tape and how well recorded it is.
And its a good idea to get plenty of hard drive space for your videos, depending on what format you plan to record them to/store them in.I have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
Converting VHS to digital, VHS tracking problems?
By ReedJohansson in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 09:54 -
Opinions on a VHS Digitization Project
By Eternal-VHS in forum Capturing and VCRReplies: 13Last Post: 29th Dec 2011, 03:44 -
Help with VHS Capturing Project
By jrodefeld in forum Capturing and VCRReplies: 3Last Post: 19th Aug 2011, 23:05 -
56 hours of Hi8 to digital project- two burning questions
By m_00 in forum Capturing and VCRReplies: 23Last Post: 6th Jul 2011, 14:27 -
Please help with VHS capture project.
By jrodefeld in forum Capturing and VCRReplies: 10Last Post: 19th Apr 2011, 10:47
