I am using Arcsoft to capture VHS home movies to my computer. I then plan on burning them to DVD in MPEG2 format.
When capturing video, it stops at points stating that it cannot continue copying as video is copyright protected??? These are home videos.
Any ideas. I need help. Thanks.
Closed Thread
Results 1 to 11 of 11
It's false Macrovision detection. One way Macrovision works is by screwing around with the sync signals. Small sync problems on home tapes can sometimes trigger the Macrovision detection built into capture and recording devices. A video "clarifier" might help. A full frame TBC should also work.
You might also try a different vcr for playback. Wouldn't hurt to try until you get a hold of a tbc.
Edit - there is a glossary on this website - link is on the top left of the page:
https://www.videohelp.com/glossary?T#Time%20Base%20Corrector,%20TBCDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Here's a video how to use the card with Arcsoft, the author is also tech support for Diamond Video:
http://www.youtube.com/watch?v=_k4AWylGTN8
My guess is it's the VCR you are using, as was mentioned borrow one from a friend or neighbor.
I was thinking trying another vcr too. The way vhs copy protection worked was that part of the signal waveform was lowered slightly in level ... the sync part of the signal.
Then, if you tried to copy from one vcr to another, with the inevitable slight signal loss you'd lose picture sync.
Problem was, if you had an old vcr with worn heads you'd get the same effect in normal play.
recording copyright protected tv
By TLE6 in forum Capturing and VCRReplies: 7Last Post: 7th Sep 2011, 12:12 -
How do i share a video on youtube without it being blocked by copyright
By andresblinky in forum Video Streaming DownloadingReplies: 3Last Post: 22nd Dec 2009, 00:59 -
Secret Copyright Treaty Leak: ISPs Worldwide to Become Copyright Cops
By joepic in forum Latest Video NewsReplies: 17Last Post: 5th Nov 2009, 10:05 -
Capturing Copyright Protected Video
By aruba92 in forum Capturing and VCRReplies: 1Last Post: 28th Aug 2008, 21:12 -
WMV License protected video
By jesterhud in forum Video ConversionReplies: 16Last Post: 9th Jul 2008, 08:38
