  1. Hi,
    I recently took about 25 GB of video with my smart phone, a Samsung Galaxy S2 Skyrocket. The phone saved each video file as a:
    - MPEG-4 movie
    - 1920 × 1080
    - AAC, H.264
    The videos play fine on my Macbook Pro, which has these specs:
    - Mac OS X 10.6.8
    - 2.53 GHz Intel Core i5
    - 4 GB Memory
    I will be sharing the videos with family, however, their computer is much older and cannot handle playback of the videos. They will be watching the videos on a TV via S-Video connection to the laptop. Their computer specs are:
    - Dell Latitude D800 laptop
    - Windows XP Pro Service Pack 3
    - Intel Pentium M 2 GHz
    - 1 GB Memory
    My questions are:
    1.) I will need to convert the HD videos to SD for my family to watch them on their Dell laptop, correct?
    2.) Which software should I use for the conversion? Free/Open Source is preferred. Mac compatible required.
    3.) What video settings do you recommend for the converted files? I would prefer to retain as much of the original video quality as possible.
    Thank you
  2. Hi
    Why not convert them to a DVD.
    If you convert them to a one hour per disc you'll be getting good quality at 720 by 480.
    Most computers and homes have a DVD player. The slowest laptop should be able to play a standard DVD.
    Good Luck
    If I'd known I was going to live this long, I'd have taken better care of myself.
  3. Banned
    Freedonia
    I'm not knocking TBoneit's suggestion, but if you want to keep more of the HD, you could convert to Divx/Xvid and downscale to 1280x720. You have to have a REALLY old PC, I'm talking like 7+ years here, for even a single core CPU to not be able to successfully play Divx/Xvid files at that resolution. The specs of that laptop should be sufficient for Divx or Xvid playback of 1280x720 video. I do not know what Mac friendly programs you can use for conversion though. Maybe ffmpeg. Don't forget to convert the audio to MP3 if converting to Divx/Xvid to further reduce the load on the CPU.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Handbrake might work. It outputs to MKV or MP4/M4V video containers, but their computer theoretically shouldn't have a problem with either of those at SD resolutions, as long as they have everything necessary to play the videos installed (like the necessary codecs, splitters and players... or an all-inclusive player like VLC, though I'm not sure about the 2.x versions).
    For shareware/commercial software (though both are relatively inexpensive, I believe), and outputting to different formats/codecs, there's ffmpegX ($15) and iffmpeg ($10). There are other choices, of course, but I don't do much video work on my Mac or Linux systems.
  5. The only reason I suggested DVD format was that it is for family members. If fire_water knew for sure there were no Apple computers in the mix then .wmv would also be a common to every windows PC format.
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    I could be wrong - I don't know how much or how well any of the ffmpeg/mencoder-based software (or VLC, for that matter) support output to Windows Media formats, but it may be difficult to produce Windows Media files on a Mac (without buying the Flip4Mac suite).
  7. I use Aimersoft Total Media Converter to convert HD to standard DVD resolution. I have also used Xilisoft Video Converter Ultimate 6 to accomplish the same task.
  8. I used Hand Brake, free and easy, to convert my HD videos to SD. Here is a link to the thread that describes how to do it:
    https://forum.handbrake.fr/viewtopic.php?f=5&t=24247
    Thank you for your help
