I captured a video into my pc using "freeVCR", which worked
fine. I had 14 AVI-files (Huffyuv-packed), each of them
2 GB in size.
The next step was to convert the AVIs to MPEG2 using TMPGenc,
and then combine the 14 MPEG2-files to two large MPEG2-Files,
using the Merge-function of the MPEG Utilities in TMPGEnc.
After burning them on SVCD, I noticed the following effect:
Each time the movie reaches one of the edges from the 7 AVI-
files (where the capture program switched from one AVI to
the next after 2 GB were written), there is a little hole
in the audio stream of about half a second.
Is there a possibility / a tool to eliminate these holes?
I have to split the AVI to several small AVI-files because
I use Win98 with FAT32.
Thank you in advace.
I dont know about the software youre using, but I use Vdub to capture to 2GB segmented AVI files and then fameserve them to TMPGEnc. Never had any problems with the audio.
Craig -
Ive just read your post more carefully. There is a problem when mergeing mpegs together with TMPGenc, sometimes you get a gap or a loud pop in the audio, I think its something to so with the audio being compressed or stretched at the merge point. Like I said in my previous post the best way of doing it is to frameserve. This fools tmpgenc into thinking that many small avi files are one large one and thus encodes to one mpeg file without the need for mergeing.
Craig
Convert dual audio from avis?
By CactusMan in forum Newbie / General discussionsReplies: 4Last Post: 12th Oct 2011, 21:06 -
Joined MTS files from Panasonic HDC-SD70, create audio delay...
By pleindepuces in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Dec 2010, 16:29 -
Is there an app that'll play AVIs and allow you to A/B (audio) them?
By takearushfan in forum Newbie / General discussionsReplies: 5Last Post: 25th Mar 2010, 05:26 -
Joined avi's have no audio
By junee in forum MacReplies: 5Last Post: 5th Feb 2010, 21:40 -
So far, VISTA has more holes than swiss cheese...
By ahhaa in forum ComputerReplies: 24Last Post: 13th Jun 2007, 20:24
