  1. I recorded couple of TV shows using WMC, file extension is TVW. Is there anyway to convert them to either mpg or iso format.
    Thanks.
    Never too old to learn
  2. Member dragonkeeper's Avatar
    Jul 2003
    Thanks.
    TVW? That's a new one on me, have you tried running the file through Mediainfo to get the file details.
    Murphy's law taught me everything I know.
  3. DECEASED
    Jun 2009
    Heaven
  4. Thank you much for the help.
  5. Banned
    Freedonia
    Please note that although it does not have to use it, that WTV does support copy protection and you will NOT be able to convert protected files. In general you should expect sources like HBO, Showtime, etc. to be copy protected. Shows on Fox, NBC, ABC and CBS (assuming you are in the USA) should not be protected. Everything is usually not protected but may be. Some of this depends on your TV provider as some have been known to protect the wrong channels by mistake or unprotect channels that they are actually supposed to protect.
