I wonder if there's a simple way to delete duplicate frames from game captures (FRAPS).
FRAPS often create duplicate frames when something chug the system. I currently use Premiere for authoring and I get rid of them manually by going frame by frame on each clip (they are 24fps so it relatively quick and it barely affect the sound).
I wonder if there's a soft or a way to do so in vDub that automatically detect the duplicate frames (and keep one!), by also cutting the sound part from the frame cut (to prevent de-syncing).
By "duplicate frames" you mean the screen capture continues at the normal speed, even when the action slows down, or stops, in the capture window?
Neither of what you describe. I talk about editing the captured .avi file, not the capture itself. I often have duplicates of the same frame pictures. Rather than getting rid of them manually in Premiere, I want to get rid in an automated way.
Decimate odd patterned duplicate frames in video
By raphaelt in forum Video ConversionReplies: 2Last Post: 2nd Feb 2011, 22:57 -
Remove Duplicate Frames
By robindean in forum Video ConversionReplies: 26Last Post: 11th Mar 2010, 15:30 -
Frame blended and duplicate frames
By loekverhees in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jan 2010, 09:35 -
duplicate frames
By qscesz in forum EditingReplies: 5Last Post: 25th Feb 2008, 11:56 -
Can I decimate duplicate frames to get 23.976
By MagicSparky in forum Video ConversionReplies: 5Last Post: 21st Feb 2008, 15:26
