hi lm trying to shoot video with panasonic hs100.
on display screen all looks fine but then on pc is greyish and looses quality?
Likely your monitor, graphics card, and/or playback software isn't properly calibrated
Not enough info. I guess we could look up your camera's specs but it would be nice if you could provide that info when asking the questions.
Video format?
Your computer specs?
The program used to view the vids on your computer? -
!!guessing games!!
I guess: "TV vs. PC scale" and/or "buggy decoder" and/or "wrong configured graphic card drivers" and/or "overlay problem"
Cu Selur -
OK I found the C/net review on your camera: "Disappointingly, though, the video just doesn't stand up to the competition. The camcorder renders good color and a fairly broad dynamic range--there are some blown out whites but nothing too severe. Unfortunately, thanks to the low-resolution sensors--even as a trio they don't have enough pixels for native 1080p HD resolution and barely enough for 720p--edges are soft and smeary with some ghosting and there simply isn't enough sharp detail."
But that doesn't explain the grayish color you are seeing. Unless you shot in a low light condition. -
But you said it looks fine on the display screen?? It can't be a fault with camera then (unless there is a recording issue)
If you want to quickly rule out a camera issue, check on a proper calibrated setup, or upload a small sample file and someone here can probably check for youLast edited by poisondeathray; 9th May 2012 at 11:35.
Imported video goes narrow---Nero 8
By will7370 in forum EditingReplies: 2Last Post: 17th Aug 2011, 23:44 -
problem with video imported into premiere
By bobspluming in forum Newbie / General discussionsReplies: 4Last Post: 28th Aug 2010, 10:26 -
Problems with Adobe dropping frames in imported video
By Texas in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2010, 14:25 -
Imported video having troubles in Vegas 8 Pro
By stantheman1976 in forum EditingReplies: 2Last Post: 16th Nov 2008, 06:17 -
Video Degrades When Imported Into Editor
By Mike_Sony_User in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 9th Sep 2008, 14:02
