Closed Thread
  1. Hi all. I have a 6gig MKV file here which I want to convert to a dual layer DVD. When using ConvertXtoDVD and specifying DVD-9 the program is outputting the files at 4.5gig, which seems wierd to me being the source file is 6gig. The file is a 720p bluray rip.
    I would of expected the file to be a lot larger, considering the size of the original source file. I have settings all set to the highest quality but still no joy. I have done similar conversions with AVI's and they can end up anywhere between 5.5gig and 7 gig.
    I'm am far from an expert on all this so if anyone can give me an idea of what I may be doing wrong I'd really appreciate the info.
    Thanks.
    Mar 2008
    How long is the source (hours and minutes).
    I've heard before that convertXtoDVD, in some circumstances, doesn't always maximize the bitrate.
    Perhaps somebody who's more familiar with it can comment.
    The fact that the source is 6GB is not particularly relevant.
  3. Running time is 2hours 16 minutes. It includes both AC3 and DTS audio as well. Here is information on the file I grabbed using MediaInfo.
    General
    Unique ID : 241731926051509980586240775391761597921 (0xB5DBE02017CF36DA85C22233AD0305E1)
    Complete name : G:\Torrents\The.Complete.Matrix.Trilogy.Bluray.720 p.DTS.2Audio.x264- CHD\The.Matrix.1999.BluRay.720p.DTS.2Audio.x264-CHD\The.Matrix.1999.BluRay.720p.DTS.2Audio.x264-CHD.mkv
    Format : Matroska
    Format version : Version 2
    File size : 6.01 GiB
    Duration : 2h 16mn
    Overall bit rate : 6 309 Kbps
    Encoded date : UTC 2010-12-03 04:22:57
    Writing application : mkvmerge v3.2.0 ('Beginnings') 编译于 Feb 12 2010 16:46:17
    Writing library : libebml v0.7.9 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 12 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 16mn
    Bit rate : 4 351 Kbps
    Width : 1 280 pixels
    Height : 532 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.266
    Stream size : 4.02 GiB (67%)
    Writing library : x264 core 107 r1772 c9dad9e
    Encoding settings : cabac=1 / ref=12 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.10:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=4351 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:0.80 / nal_hrd=none
    Language : English
    Default : Yes
    Forced : Yes
    Audio #1
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 2h 16mn
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 1.44 GiB (24%)
    Title : English DTS-HDMA core 5.1 1509Kbps
    Language : English
    Default : Yes
    Forced : Yes
    Audio #2
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 2h 16mn
    Bit rate : 448 Kbps
    Bit depth : 16 bits
    Stream size : 437 MiB (7%)
    Title : Mandarin AC3 5.1 448Kbps
    Language : Chinese
    Default : No
    Forced : No
    canada
    Please do not ask for help on illegally downloaded movies.This thread is closed.
