What is prefered, to leave it at max 100% and control from the speakers or lower the players volume to prevent the speaker from distorting the audio itself? I find in MPC having it at near 60% to give less distortion no matter how high i go with speaker's volume relativily but not vice versa.
Yes, software players can definitely distort volume. However it depends upon the player.
But it'd be quite unlikely that you'd get best results at 60% volume. You may be overdriving a preamp stage or your speakers.
If there's a global setting for mpc-hc volume (I forget, I uninstalled it some time ago) it may be set to max 250% or whatever.
See here for an excellent explanation of how problems can arise (Benchmark makes state of the art audio D/A and A/D converters and, since their stuff is aimed at the pro market, the tech support is really good):
http://www.benchmarkmedia.com/wiki/index.php/Digital_volume_control
I actually use smplayer or, rarely, vlc just for video. For audio it's foobar2000. Despite the clunky interface and Godawful docs it just works. For it I leave the volume at 100% and use the windows global volume control, which works well.
Free tool to mask/distort part of a moving object
By myowntemp in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jan 2012, 12:44 -
How to create a BluRay from odd format videos and not distort the picture?
By Peterk312 in forum Video ConversionReplies: 5Last Post: 16th Jul 2011, 21:49 -
Volume Controls on a canopus ADVC300
By billycar in forum Capturing and VCRReplies: 8Last Post: 6th Apr 2010, 13:29 -
Video player with good color controls
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 07:21 -
How to Replace/Distort Uncensored Scenes in a movie with Blank
By ishopper in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2009, 01:54
