I have an AVI video file (no audio , just video) and its about 4minutes and it ways 53.3MB which is rather to heavy for a 4minute video without audio . so i am trying to shrink this video to about 10 or 15mb with virtual dub . I have seen articles online here : http://maketecheasier.com/how-to-compress-a-video-file-with-virtualdub/2009/05/31 and here http://www.makeuseof.com/tag/compress-videos-send-email/ on how to use virtual dub BUT in my own case whenever i try to shrink my video i get an "error 100" message . I would appreciate some help or suggestions . Here is the video analysis from media info:
General
Format : AVI
File size : 53.5 MiB
Duration : 3mn 42s
Overall bit rate : 2 020 Kbps
Video
Format : TechSmith
Codec ID : tscc
Codec ID/Info : TechSmith Screen Capture
Duration : 3mn 42s
Bit rate : 2 014 Kbps
Width : 313 pixels
Height : 224 pixels
Display aspect ratio : 1.397
Frame rate : 15.000 fps
Bits/(Pixel*Frame) : 1.915
Stream size : 53.3 MiB (100%)
1st one is used to allow Virtual Dub to decode the input (Preview windows should show something now)
2nd one needs to be selected and configured under video->compression.
Option a. : readup
1. read up on how Virtual Dub works: http://negativesum.net/tech/tools/VirtualDub.pdf
2. read http://mewiki.project357.com/wiki/X264_Settings to understand the meaning of the setting in the x264vfw configuration (the page linked is not ment for x264vfw, but it should help to understand the options presented)
Option b. : Wait for someone to write you a guide
Wait for someone to write you a step-by-step guide, that fits your problem.
Cu Selur -
I understand that the video width is the problem as their are not divisible by 2 . On virtual dub > video> filter > add > resize , i am trying to resize my video to 322 x 222 which is the closest to what my video is now 333 x 224 however when i type in 322 the other width automatically changes by itself . how can i force the video to accept the size i am assign to it using the resize option . Please help .
http://www.virtualdub.org/blog/pivot/entry.php?id=95 -> setting Aspect Ratio to disabled should allow to adjust width&height independently
btw. I'm still unclear on why use use resize instead of simply cropping (http://www.virtualdub.org/docs_processing.html) one pixel, but you probably have a reason for it,... -
I would crop one line off the width (leaving 312x224) rather than resize. The quality will be better.
AC3 to MP3 in AVI via Virtual Dub
By Simmons in forum AudioReplies: 7Last Post: 22nd May 2012, 18:16 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 20:27 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 22:47 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 16:21
