I have some questions about the configuration settings of my RS45 projector (display device).
1. HDMI Input
I can selecact Standard (16-235), Enhanced (0-255) or Super White (16-255).
What is the setting that should be used when using a HTPC with:
- Blu-Ray content to play
- Media Player Classic Home Cinema
- madVR as output renderer (set to PC levels 0-255 as RGB output levels)
- LAV video filter (RGB set to 'untouched' in LAV video filter)
- NVIDIA GTX460 with default 1080p23 profile BUT with n vidia fix during installation (for further information about this fix check http://forums.nvidia.com/index.php?s...post&p=1328716)
2. Color Space
I can select YCbCr (4:4:4), YCbCr (4:2:2) or RGB. It seems that only RGB seems to show the correct colours. I thought Blu-Ray specification was 4:2:2?
no 4:2:0 but monitors normally always show RGBI thought Blu-Ray specification was 4:2:2
Another question. I just found out that the RS45 has a second color space setting (in the picture adjust settings so NOT in the hdmi settings). The manual says that you can switch the color space display of the projector output.
Settings to choose from are:
- Standard
Equivalent to the HDTV color space
- Wide 1
Equivalent to the color space of the DCI standard
- Wide 2
A color space that is broader than Wide 1
Any idea which I have to choose when looking at my config?
my config:
HTPC with:
- NVIDIA GTX460 with default 1080p23 profile BUT with n vidia fix during installation (for further information about this fix check http://forums.nvidia.com/index.php?showtopic=216099&view=findpost&p=1328716) -
No clue, about the color space settings in the RS45,... I guess simply trying the three options out is the fastest way to check which looks right.
Softsub in Avi Does Not Display In MPC
By Docoptik in forum SubtitleReplies: 2Last Post: 6th Nov 2011, 13:00 -
HTPC Guide with mpc-hc ffdshow reclock madVR... on HomeCinema-HD
By je_rem_y in forum Software PlayingReplies: 0Last Post: 12th Feb 2011, 09:53 -
How to get MPC to display images?
By SignedupGuest in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2010, 15:31 -
MPC - Subtitles won't display on secondary device, VMR7/9
By John_Jordan in forum Software PlayingReplies: 1Last Post: 12th May 2009, 09:57 -
help with video capture device config/ stream format
By fergwannville in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2008, 09:12
