I can't seem to get multiAVCHD 4.1 to work for me. Any other suggestions to try or programs that can do this for me?
a few of the errors i get are:
Video is not AVCHD/BDMV compliant!
Detected frame reference count: 12 (max:6).
Audio conversion failed! (eac3to)
eac3to didn't succeed...
Cannot detect file size: (c:\multiAVCHD\_TEMP\multiTEMP-20120507\temp-2.pcm) (RS:0)
several other red lines of unhappiness.
	Will do, and i'll come back in a few hours after I've played with it.
	Good luck.
 I'm not sure if it can take mkv directly. At worst assuming these are h264 mkv files you could demux them. However I am pretty sure tsmuxer can take a mkv as it is.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  Converted MKV to Bluray-Seems no different?By Ziani in forum Authoring (Blu-ray)Replies: 9Last Post: 4th Nov 2012, 15:31
  MKV with MKV Merge Unicode not compatible with LG BluRay PlayerBy klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42
  bluray 3-d to mkv?By dave_o in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2010, 08:38
  Problem with BluRay to MKVBy carbanista in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2009, 23:58
  Bluray -> MKVBy unknown12 in forum DVD RippingReplies: 3Last Post: 22nd Jan 2008, 16:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
