hello, I am Sorenson Squeeze user. please, anyone tell me, how should I modify these options in x264 codec to result best, highest output video quality? (I don't mind and don't care about encoding speed or CPU performance. just need best quality)
P.S. please don't care about understanding explanations, just tell me what should be the best options to applythanks...
You can olso see the images from the software.
http://img526.imageshack.us/img526/8541/22850171.png
http://img225.imageshack.us/img225/7941/63059913.png
http://img155.imageshack.us/img155/1092/13165359.png
http://img845.imageshack.us/img845/6233/86989266.png
http://img72.imageshack.us/img72/6333/59372762.png
http://img163.imageshack.us/img163/6116/22454727.png
http://img515.imageshack.us/img515/1248/70936474.png
http://img513.imageshack.us/img513/3526/40698857.png
CRF max: _ (24...100)
Tuning: _ stillimage
psnr
ssim
none
Zero latency _ YES or NO
AVC Profile: _ baseline
main
high
high 10
Intra refresh _ YES or NO
Number of B-frames _ (0...100)
Adaptive B-frame placement: _ Pick B-Frames always
Fast algorithm
Optimal algorithm
B-frame bias _ (P-frame_-100...100_B-frame)
B-frame pyramid: _ none
strict
normal
Decoded Picture Buffer _ (1...16)
Deblocking loop filter: _ YES or NO
Deblocking strength _ (-6...6)
Deblocking threshold _ (-6...6)
Constrained intra prediction: _ YES or NO
Always mark stream interlaced _ YES or NO
Send pic_struct in Picture Timing SEI: _ YES or NO
mb-tree ratecontrol lookahead _ (0...250)
Chroma quantizer offset _ (-51...51)
Adaptive Quantization Mode: _ Do not use AQ
AQ across video and frames
Auto-variance AQ per frame
Adaptive Quantization Strength _ (0...2)
Use Macroblock Tree Ratecontrol: _ YES or NO
Quantizer curve compression factor: _ (0...1)
Quantizer curve blur radius: _ (1...1000)
'direct' motion vectors prediction mode: _ auto
spatial
temporal
none
Weighted B-frame references: _ YES or NO
Weighted prediction in P-frames: _ disabled
simple
smart
Motion Estimation method: _ dia
hex
umh
esa
tesa
Pixel estimation complexity: _ fullpel only
QPel SAD 1 iteration
QPel SATD 2 iterations
HPel on MB, the QPel
Always QPel
Multi QPel + bi-directional ME
RD on I/P frames
RD on all frames
RD refinement on I/P frames
RD refinement on all frames
QP-RD
Psy-RDO strength: _ (0...100)
Psy-Trellis strength: _ (0...100)
Psy optimizations: _ YES or NO
Use mixed refs per 8x8 partition: _ YES or NO
Use chroma motion estimation: _ YES or NO
Use adaptive 8x8 DCT: _ YES or NO
Trellis quantization: _ disabled
on final encode of MB
on all mode decisions
early skip detection on P-frames: _ YES or NO
Allow DCT decimation: _ YES or NO
Fast Noise Reduction _ (0...1000)
Luma Quantization Deadzone (inter) _ (0...32)
Luma Quantization Deadzone (intra) _ (0...32)
Quantization Matrices Preset: _ flat
JVT
Number of threads _ (0...256)
Number of frames for threaded lookahead _ (0...250)
Allow non-deterministic output: _ YES or NO
Use access unit delimiters: _ YES or NO
Put SPS/PPS before each keyframe: _ YES or NO
Max quantizer step _ (1...51)
			Closed Thread
	Couple of things:
 Unless I'm quite mistaken, the h.264 encoder in Squeeze does NOT make use of x264 (the codec implementation). Likely, you have a Mainconcept or similar implementation, or Sorenson's own.
 But if I AM mistaken and you somehow can get x264 to work from within SS, you would probably need to understand a little more about how codecs work.
 Because one of the first things about tweaking codec settings is: Much of the choices depend upon the actual program content which is unique, varying from one to the next. Fast action/Quick cuts is different from Talking heads, Animation is different from Natural content, etc. And so are the most optimal settings.
 Plus, a lot depends on: WHAT YOU WANT TO DO WITH THIS FOOTAGE. Stream online, distribute to friends, Play in PC, settop, phone, media player, gaming device. Which models, etc. They all vary and have varying needs. Those needs dictate how you make the choices in the settings...
 If you don't want to learn why it works the way it does (so you could adjust HOW it works), your best bet is the safest: stick to default profile templates. But that WON'T get you the very Best quality (good, but not the best).
  mencoder x264 vs libavcodec for h.264 encodingBy chconnor in forum Video ConversionReplies: 0Last Post: 2nd Mar 2011, 16:31
  Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12
  X264 encode switches/options retrievalBy padiwa in forum Video ConversionReplies: 2Last Post: 11th Jan 2010, 10:28
  X264 or H.264By user123456 in forum Newbie / General discussionsReplies: 9Last Post: 25th May 2009, 17:21
  x264 CRF best for iPod encoding? Coder Options Quandary.By radellaf in forum DVD RippingReplies: 0Last Post: 28th Mar 2008, 10:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
