Quick question, I am going to be building an XP machine for all my video capturing (S/VHS sources) and would like to know if using a 1TB hard drive as the data drive will work in XP. I have a smaller spare hard drive that I will use for the OS and programs, which won't be much. I believe it should work okay, but needed to make sure.
I have the staff of power, now it's up to me to use it to its full potential to command my life and be successful.
Not for capturing VHS footage and the work involved. The best hardware for that job works best on an XP box, as there aren't any reliable analog capture cards for Windows 7 that can capture uncompressed AVI using the Huffyuv codec.
I do plan to build a new i7 workstation machine in the coming months that will take care of the HD video needs and newer stuff, but for the older analog stuff I will build a separate XP capture box just for that purpose. I just needed to see if the 1TB to be used as storage will work.I have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
XP will have no problems with a 1 TB drive. You don't have to worry until you get over 2 TB.
Yeah XP 32 bit has a 2TB limit but there are ways around that:
http://www.dulcesystems.com/html/2tb_limit.html -
Yes, confirmed - it works. I have an XP 32 bit box that runs both 1 TB and 2 TB HDDs.
What will I need to add a 1TB internal hard drive to my PC?
By Captain Satellite in forum ComputerReplies: 12Last Post: 9th Dec 2008, 10:17 -
Does 1TB hard drive works on Philips dvp 5990/2
By waefwaeefwaefw in forum DVD & Blu-ray PlayersReplies: 9Last Post: 8th Dec 2008, 21:52 -
Compare 1TB Hard Drive - Which One to Choose
By mn072065 in forum ComputerReplies: 5Last Post: 21st Apr 2008, 13:18 -
Need advice on 1TB Hard Drive Please
By mn072065 in forum ComputerReplies: 15Last Post: 26th Mar 2008, 17:02 -
1TB hard drive only $260
By piano632 in forum ComputerReplies: 32Last Post: 4th Oct 2007, 20:45
