What's the best way to produce a DDP file and have control over the layer break? Encore will produce the correct file, but puts the layer break wherever it pleases. GEAR Pro is $600. Is there another option?
If you noticed i said use encore to output a folder,no need to make a DDP image file in the first place unless your sourcing it out to a master recorder.
Im pretty sure he is going to replication if he's asking about setting layer breaks in DDP imagesIf you noticed i said use encore to output a folder,no need to make a DDP image file in the first place unless your sourcing it out to a master recorder.
Can't seem to get the layer break set right.
By Jon.G in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2011, 21:53 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Layer Break Using ImgBurn Help
By Nitro89 in forum Authoring (DVD)Replies: 8Last Post: 30th May 2010, 08:01 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
