I've compiled a super DVD in DVD Lab Pro, and I have some roof left on the disc to include complimentary reading files that go along with the videos on the DVD. Is that possible? I have a Mac, so I'm looking for either Windows apps or OS X apps. They will both work with my setup. I need to be able to add an EXTRAS folder to the DVD disc that contains PDF documents for a user to access on their computer from the disc, but I don't know what to look for. Any pointers and help would be wonderful!
Results 1 to 12 of 12
Yes. You could output as VIDEO_TS folder in dvd lab pro. Then use IMGBURN to add the VIDEO_TS folder, see http://forum.imgburn.com/index.php?showtopic=4632 and then make a new folder and add your pdf documents.
What?
DVDLab Pro doesn't detect your hard drive?....because that is where you instruct DVDLab Pro to put the VIDEO_TS folder. -
heck54,
IMGBURN does not detect my optical drive, so I can't follow the tutorial as it is written. And since the tutorial is about "How to write DVD Video files directly to single layer media using ImgBurn" rather than "How to add non dvd content to a DVD disc for viewing on a computer" I'm not exactly sure how to follow it to accomplish what I want to do here.
I've already output to folder with DVD Lab, and everything is fine thus far. There are some PDF documents that accompany the videos which I want to include on the disc. Obviously they wouldn't be accessible from a DVD Player, but I was hoping that with a computer, a user could access the additional documents if they wanted to, from the same disc that the DVD content is on. -
I find it interesting but disappointing, that ImgBurn doesn't recognize your optical drive. What model is it? Maybe LightningUK can find a way to add it to his roster.
In the meantime, do everything that was mentioned except instead of "write image file to disc" or "write files/folders to disc" you use "create image file from files/folders" and output to an .ISO image file. Then burn with Toast or something similar on your Mac (where presubably it DOES recognize your burner). BTW, if those don't recognize your burner either, you ought to think about getting a different burner.
Scott -
So I open up a "create image file from files/folders", drag AUDIO_TS, EXTRAS (which contains the PDFs I want to be able to access if I put the disc in a computer), AND VIDEO_TS to the composition window. And then export as an ISO file? Forgive me for my ignorance if I'm showing it, but won't this make a DATA DVD that isn't playable in DVD component boxes as a Video DVD? Doesn't the DVD have to be prepared as a Video DVD?
VIDEO_TS folder goes first....then your DATA folder....press the calculator icon. Dialogue should appear below showing you/verifying that it recognized the VIDEO_TS folder and that it will be creating a DVD Video image. I believe another tell-tale sign is that in that list it will also show region information and video format(PAL, NTSC). If you see that you are good to go.
It worked. Thanks for the help, everybody. Will gladlybe passing this info on to other people looking to do the same thing.
Big video project with NTSC and PAL-material
By garylanders in forum Capturing and VCRReplies: 0Last Post: 3rd Jul 2011, 07:09 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Video on demand Material (VOD): Anydvd or Other Program to Handle That?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2008, 19:20 -
How do I handle both video and film-based material?
By CubDukat in forum DVB / IPTVReplies: 2Last Post: 20th Sep 2008, 20:12 -
How to add extra MB to wmv
By sirganisch in forum Newbie / General discussionsReplies: 7Last Post: 12th Jun 2008, 13:25
