Maybe the title doesnt make sense, as I re-read it... Im confused!
Ive got a nifty QB45 executable that Id like to call from a batch file, the exe outputs text (stdout), Id like to capture the exe's output into a variable in a batch file.
Any ideas? Im a DOS junkie... Was working with computers waaaay before Windows 3.0!
Thanks for any help,
Andrew
Just figured it out...
for /f "tokens=*" %%a in ('dtshow.exe') do set dt=%%a
echo %dt%
Where dtshow.exe is my executable, and var dt is set to it's output..
Andrew -
There are many ways to do this, I'm a bit rusty haven't written a bath script in years.
Another another method would to set an environmental variable then read it, just be sure to do house clean afterwards. Or you can pipe the output to a text file and read from the text file, which is i use to do when building the batch scripts. I could run the program once to generate the text file, then build the script using the generated text file as my source. I could make necessary corrections & tweaks all without re-running the program which in environment i was a plus, it could take some time to rerun a program.
But one of things I liked to do was wrap an HTA around the scripts so end users/clients could run the script (everyone is intimidated by command line). In the HTA I could use activeX to create an instance of "WScript shell" to run external programs and set JavaScript variables. You gain access to all the shell commands as well, you would be suprised at the things you could do with this method it takes your windows scripting writing capabilities to new heights.Murphy's law taught me everything I know.
Google redirect virus, I can not remove it...
By Denvers Dawgs in forum ComputerReplies: 12Last Post: 27th Aug 2014, 06:19 -
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Highlight parameter breaks redirect
By thecoalman in forum FeedbackReplies: 0Last Post: 21st Jun 2010, 12:18 -
Avisynth: no executable?
By quark4iitg in forum Video ConversionReplies: 2Last Post: 13th Oct 2009, 22:44 -
How to redirect Windows temporary file to Ramdisk?
By Webster in forum ComputerReplies: 4Last Post: 30th Oct 2008, 07:26
