I use several different cameras, 3 of which I *know* are CMOS. I am also using the fab pluging Deshaker...
In order to apply the proper percentage amount (Version 3), I was wondering is there an app or avisynth script or anything that I could use to give me the percentage?
I hope I make sense.
Thanks for any input..
Andrew
You have to measure it, unless someone has the same camera and already reported it (there is a list)
The instructions are on the homepage
http://www.guthspot.se/video/deshaker.htm -
Ahh... I missed the destructions... Ill give it a try! Thanks for the help!!
Rolling Shutter and Deshaking
By blewyn in forum EditingReplies: 8Last Post: 5th Feb 2012, 15:45 -
How to calculate rolling shutter percent
By zzyzx2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 27th Jul 2010, 23:41 -
Shutter speed settings with TL-light
By B-Twien Bytes in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2010, 03:09 -
Progress percentage is under-reported
By tomf84 in forum ffmpegX general discussionReplies: 4Last Post: 5th Jan 2009, 04:34 -
Percentage (%) going over 100 %
By enzofsilva in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2007, 22:26
