Hello. I have a Samsung hd player at home. I play my movies by putting the mkv files onto an external HDD and then plugging it to the HD player. The problem is that when I try to play movies with bitrate over 25mb/s, the movie starts lagging and it makes pauses from time to time. This does not happen with movies with bitrate less than 25mb/s. So what do I do?
you can either get a new player , or re-encode using lower bitrate (if that's really the cause) and/or compatible settings
you might use something like ripbot264, handbrake, megui , avchdcoder, (many others)...
for maximum compatibility , you probably want to use "AVCHD" compatible settings
check with samsung forum also, sometimes a certain firmware issue might "fix" the playback problem -
That is what I'm asking. how do i re-encode. i dont know how to do this. please explain it to me and tell me which programs i have to use
perhaps you typed before the message board processed the edit I made.
e.g. ripbot, handbrake, megui, avchdcoder
there are many guides on how to use the programs when you click on the links
avchdcoder is probably a safe bet to re-encode for compatibility -
thanks. but does this process take too long. say, for a 20 gb movie, how much time would it take to reduce the bitrate
It depends on hardware, and quailty/compression settings used. It can take anywhere from couple hours , or days. And you always lower the quality. Current hardware players cannot player the lossless compression varieties
If possible, usually better idea to get more compatible hardware player
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 05:17 -
80% MKV remux on H.264 - M2ts remux Aero Theme
By BJ12 in forum Video ConversionReplies: 2Last Post: 12th Aug 2011, 13:59 -
Would like to remove or at least reduce wind sound from M2TS video
By kmw in forum AudioReplies: 5Last Post: 11th Nov 2010, 20:06 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 22:25 -
Can remux .mkv to .m2ts with tsMuxer but how to do the reverse?
By MilesAhead in forum Video ConversionReplies: 8Last Post: 22nd Apr 2010, 15:27
