  1. Does MPC HC use hardware color controls or software color controls? Can I get it work on a PC that does not have graphics card? None of the renderers seems to move the sliders on color controls?
  2. It has color control settings under options / miscellaneous.
  3. I believe MPCHC can use either hardware or softare color controls depending on the output device.
  4. DECEASED
    Jun 2009
    Heaven
    You have to use VMR9 or EVR if you want hardware-based image control.
    Also, the video card must support DirectX version 9, minimum.
  5. Mrs Intel Core i7's Avatar
    Mar 2011
    Mainland E.U, concierge
    Only encountered "enigma-limited power 5.1 2 use mpc codec and by now still
    I have nooo idea what it means and why it isnt mpa.
