Hi all,
I have three WMV files, I think ASF encoded (if that's the right term). I've tried to convert them to AVI, MPEG, and other formats, but the quality is always substantially degraded (very muddy and pixelated), no matter how high I set the conversion quality.
I've used Freemake Video Converter and Avidemux2. Same poor results with both, but this could very well be because I don't know how to tweak the settings properly.
Any ideas? Maybe convert them to some uncompressed format, if so how?
Thanks in advance!
Results 1 to 12 of 12
Thanks! Hope it makes sense
Code:General Complete name : I:\LS1.wmv Format : Windows Media File size : 1.38 MiB Duration : 22s 121ms Overall bit rate mode : Constant Overall bit rate : 525 Kbps Maximum Overall bit rate : 547 Kbps Movie name : Performer : Encoded date : UTC 2005-10-03 03:31:27.970 Video #1 ID : 2 Format : WMV2 Codec ID : WMV2 Codec ID/Info : Windows Media Video 8 Description of the codec : Windows Media Video V8 Duration : 22s 133ms Bit rate mode : Constant Bit rate : 25.2 Kbps Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate : 15.000 fps Bit depth : 8 bits Bits/(Pixel*Frame) : 0.022 Stream size : 68.0 KiB (5%) Language : English (US) Video #2 ID : 3 Format : WMV2 Codec ID : WMV2 Codec ID/Info : Windows Media Video 8 Description of the codec : Windows Media Video V8 Duration : 22s 122ms Bit rate mode : Constant Bit rate : 424 Kbps Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Bit depth : 8 bits Bits/(Pixel*Frame) : 0.184 Stream size : 1.12 MiB (81%) Language : English (US) Audio ID : 1 Format : WMA Format version : Version 2 Codec ID : 161 Codec ID/Info : Windows Media Audio Description of the codec : Windows Media Audio 9 - 64 kbps, 44 kHz, stereo (A/V) 1-pass CBR Duration : 22s 120ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Stream size : 173 KiB (12%) Language : English (US)
not as detailed as I hoped, but I think the main reason you output has such a bad quality, might be because Avidemux reencodes the 1st and not the second video stream.
Cu Selur
Ps.: No clue if Avidemux allows you to select which video stream to reencode,.. (Hybrid should, but it's harder to configurate, so not really for newbies, but it might be worth a try,..) -
Sorry, I tried both the tree and sheet views, but this is all the info they provided. :/
I'm also not finding anything for selecting specific video streams in Avidemux, so I'm going to ask in their forum. I'll also see if I can muddle my way through Hybrid.
Thanks again
Perhaps you can use asfbin , to select the proper stream. video stream #1 looks to be very low quality 15fps, 25kbps bitrate (make a new wmv/asf, where only the proper video remains, so your converter program has no choice but to use the proper stream)
But , as Baldrick asked earlier - why are you converting these at all? You only lose quality, unless you use a lossless format. If you use a lossless format, filesize will increase, easily 5-10x -
[QUOTE=poisondeathray;2160320]Perhaps you can use asfbin , to select the proper stream. video stream #1 looks to be very low quality 15fps, 25kbps bitrate (make a new wmv/asf, where only the proper video remains, so your converter program has no choice but to use the proper stream)
I'll give that a try, thanks.
EDIT: That worked, thanks!!!
I want to group them as a single AVI file. Currently when I do that the quality is poor, apparently because it's the 1st video streams that are being used. I'm not concerned about file size, since they're each less than a minute long. So, if I can convert the 2nd streams to usable AVIs, I can them group them together.Last edited by elcoyoteloco; 5th May 2012 at 15:29.
@Selur:
I just tried using Hybrid, selecting Video 2, but I'm getting the following errors. What am I doing wrong?
Code:Log Messages Added new job with id 14_58_40_321 Added new job with id 15_00_39_221 Optional components are missing: - fhgaacenc is used for aac/alac encoding,... If you want to use one of them, you can: - specify where to find the tool(s) (Config->Path Settings) - save settings (Config->Defaults->Save->GlobalModel and hit 'Selected') - restart Hybrid) analysing: I:\New folder\LS2.wmv grabbing audio ids ... analysing audio streams... analysing audio stream (1) with mplayer grabbing video ids for: I:\New folder\LS2.wmv analysing video streams... Analysing video stream 2 with MediaInfo! Analysing video stream 3 with MediaInfo! createJobs for I:\New folder\LS2.mp4 createJob video... Added new job with id 15_20_39_981 x264 (1st pass bitrate) encoding started... Starting Main@15:20:55.067: "C:\Program Files\Hybrid\x264.exe" --pass 1 --bitrate 1500 --profile high --level 4.2 --direct auto --sync-lookahead 15 --weightp 1 --aq-mode 0 --stats "\LS2_15_20_39_981_01.stats" --fps 15 --input-res 320x240 --output NUL - raw [info]: 320x240p 0:0 @ 15/1 fps (cfr) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [info]: profile Main, level 4.2 x264 [info]: frame I:2 Avg QP: 3.59 size: 22882 x264 [info]: frame P:284 Avg QP: 0.20 size: 8318 x264 [info]: frame B:39 Avg QP: 1.63 size: 4903 x264 [info]: consecutive B-frames: 84.0% 0.0% 0.0% 16.0% x264 [info]: mb I I16..4: 9.2% 0.0% 90.8% x264 [info]: mb P I16..4: 0.8% 0.0% 0.0% P16..4: 83.3% 0.0% 0.0% 0.0% 0.0% skip:15.9% x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 57.3% 0.0% 0.0% direct:26.0% skip:16.7% L0:46.5% L1:42.4% BI:11.0% x264 [info]: final ratefactor: -6.20 x264 [info]: direct mvs spatial:94.9% temporal:5.1% x264 [info]: coded y,uvDC,uvAC intra: 95.0% 97.1% 94.5% inter: 53.2% 46.2% 45.9% x264 [info]: i16 v,h,dc,p: 26% 37% 27% 11% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 32% 6% 4% 11% 8% 8% 5% 7% x264 [info]: i8c dc,h,v,p: 40% 27% 22% 10% x264 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x264 [info]: kb/s:959.77 encoded 325 frames, 562.28 fps, 959.77 kb/s finished after 00:00:00.653 finished... x264 (2nd pass bitrate) encoding started... Starting Main@15:20:55.734: "C:\Program Files\Hybrid\x264.exe" --pass 2 --bitrate 1500 --profile high --level 4.2 --direct auto --sync-lookahead 15 --partitions i4x4,p8x8,b8x8 --no-fast-pskip --subme 5 --trellis 0 --weightp 1 --aq-mode 0 --vbv-maxrate 62500 --vbv-bufsize 78125 --colormatrix bt470bg --stats "\LS2_15_20_39_981_01.stats" --fps 15 --input-res 320x240 --output "LS2_15_20_39_981_02.264" - raw [info]: 320x240p 0:0 @ 15/1 fps (cfr) x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [warning]: target: 1500.00 kbit/s, expected: 1110.29 kbit/s, avg QP: 0.0000 x264 [warning]: try reducing target bitrate x264 [info]: profile High, level 4.2 x264 [info]: frame I:2 Avg QP: 0.00 size: 29125 x264 [info]: frame P:284 Avg QP: 0.00 size: 7974 x264 [info]: frame B:39 Avg QP: 0.00 size: 5552 x264 [info]: consecutive B-frames: 84.0% 0.0% 0.0% 16.0% x264 [info]: mb I I16..4: 5.5% 17.5% 77.0% x264 [info]: mb P I16..4: 0.1% 0.0% 1.1% P16..4: 67.3% 8.1% 6.6% 0.0% 0.0% skip:16.7% x264 [info]: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 43.2% 12.3% 1.8% direct:26.4% skip:16.3% L0:46.9% L1:45.0% BI: 8.2% x264 [info]: 8x8 transform intra:6.4% inter:7.2% x264 [info]: direct mvs spatial:100.0% temporal:0.0% x264 [info]: coded y,uvDC,uvAC intra: 97.3% 96.6% 94.1% inter: 53.1% 44.9% 44.9% x264 [info]: i16 v,h,dc,p: 14% 26% 10% 49% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 39% 5% 1% 16% 4% 18% 1% 3% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 34% 9% 4% 8% 7% 6% 4% 6% x264 [info]: i8c dc,h,v,p: 37% 26% 24% 12% x264 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x264 [info]: ref P L0: 94.9% 4.2% 0.9% x264 [info]: ref B L0: 97.6% 2.1% 0.3% x264 [info]: ref B L1: 99.1% 0.9% x264 [info]: kb/s:937.65 encoded 325 frames, 284.59 fps, 937.65 kb/s finished after 00:00:01.217 finished... deleted \LS2_15_20_39_981_01.stats deleted \LS2_15_20_39_981_01.stats.mbtree Starting Main@15:20:56.967: "C:\Program Files\Hybrid\MP4Box.exe" -fps 15 -add "LS2_15_20_39_981_02.264"#video:par=1/1:name="" -brand avc1 -tmp -new "I:\New folder\LS2.mp4" Cannot open destination file I:\New folder\LS2.mp4: I/O Error finished after 00:00:00.085 with exitCode 1 finished... I:\New folder\LS2.mp4 was not created! Job 15_20_39_981 finished!
Basically what I'm saying is discard video#1 track, so only video#2 track remains (the higher quality version), so the converter software has no choice but to use the higher quality version. ASFBin should be able to do it (just unchekmark the appropriate video stream) , if not, windows media stream editor should be able to as well
If you want to append a group of videos (join them end to end) they have to be the same characteristics like frame rate, audio sample rate etc...even if you convert them to avi first. For example, one of your video streams is 15 fps, the other is 29.97 fps. If the "good" stream in some of your other videos were not exactly the same characteristics, it won't join properly. In fact, its better to join them before converting, less likely to encounter problems.
FLV versus WMV formats
By shaema in forum Video ConversionReplies: 5Last Post: 15th Sep 2009, 09:24 -
Converting multiple formats to WMV
By StrangeSolutions in forum Video ConversionReplies: 5Last Post: 9th Dec 2008, 19:43 -
How to convert WMV to other formats? (Thanks)
By seymoria in forum Video ConversionReplies: 5Last Post: 20th May 2008, 18:12 -
Converting an ASF (WMV) file
By yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 06:16 -
WMV files go with which subtitle formats?
By binocular222 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2007, 10:49
