Hi,
I've been using MeGUI for a while but only recently realized that adding sub files during the encoding process results in a hardsubbed video. Is there a way to add the sub during the MeGUI encoding process that allows softsubs.
I know that MKVToolnix can easily import the sub files but I thought I could save a step if its possible through the MeGUI encoder.
You could always use the built in mkvmux, tools->muxer->mkvmuxer. BUt I don't think you can do it automatically.
Thanx, I didn't even know that MeGUI had this fuction but MKVToolnix does the same thing anyway and has more muxing options.
I would consider using it if MeGUI had added the muxing option into the scripting so that I could batch encode. Unfortunately it is only usable once the encoding is completed and there is no way to batch this function either.
Softsub in Avi Does Not Display In MPC
By Docoptik in forum SubtitleReplies: 2Last Post: 6th Nov 2011, 12:00 -
Adding softsub with mkvmergeGUI for mpclassic
By douberman in forum SubtitleReplies: 2Last Post: 28th Jul 2011, 00:37 -
How to make softsub from hardsub subtitle
By lequios in forum Newbie / General discussionsReplies: 6Last Post: 24th Jul 2010, 00:50 -
Making Softsub into Hardsub
By iKhoa in forum SubtitleReplies: 0Last Post: 2nd Jul 2010, 13:58 -
Softsub mkv ----> hardsub avi?
By Silvertroy in forum Video ConversionReplies: 2Last Post: 1st Jun 2008, 11:14
