Results 1 to 29 of 29
  1. Member Deblk's Avatar
    May 2012
    Hey...I am trying to play MKV file which I have converted from AVI file on my Blu ray player to watch on television. I know that the player should play these files and have done once before but have problems with most. I copy to it to a USB, plug in which player picks up, select file then am told to wait for a while then get the option to play then get black screen. Can anybody tell me what I maybe doing wrong, thanks.
  2. AVI and MKV are containers. They can contain audio and video encoded with any of a number of different codecs. Players typically only handle certain codecs. Figure out what you player requires and convert to those specs. Blu-ray players that play MKV typically take h.264 video and AC3 or MP3 audio. You can use MediaInfo to see what codecs and properties your files have.
  3. Member Deblk's Avatar
    May 2012
    Thanks jagabo. Below is the info from MediaInfo...Can you give me an idea of what I should be tweaking?
    General
    Unique ID : 184987112444769441621290835985851673141 (0x8B2B38CFA37032128F61367058CAEA35)
    Complete name : C:\Users\Debbie\Videos\tel10.mkv
    Format : Matroska
    Format version : Version 1
    File size : 858 MiB
    Duration : 1h 26mn
    Overall bit rate : 1 392 Kbps
    Encoded date : UTC 2012-05-04 13:39:53
    Writing application : AVSMatroskaFile
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    Video
    Format : AVC
    Format profile : Main@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 1h 26mn
    Bit rate : 1 172 Kbps
    Width : 712 pixels
    Height : 356 pixels
    Display aspect ratio : 2.000
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.193
    Stream size : 723 MiB (84%)
    Default : Yes
    Forced : No
    Audio
    Format : MPEG Audio
    Format profile : Layer 3
    Codec ID : A_MPEG/L3
    Codec ID/Hint : MP3
    Duration : 1h 26mn
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 118 MiB (14%)
    Writing library : LAMELAME_MAJOR_VERSI
    Default : Yes
    Forced : No
  4. Is that a file that doesn't play? Do you have specs for a file that does play? For comparison.
  5. Member Deblk's Avatar
    May 2012
    Yes it is. No I don't have that file anymore that played so have nothing to compare. My player is a Sharp BD-HP25.
  6. Are you using a recent version of MediaInfo? There is an MKV feature that causes problems for many players but old versions of MediaInfo may not show it.
    Try this: download MkvToolnix. Start the program called MMG.EXE (Mkv Merge GUI). Select File ->Options. On the MMG tab, put a checkmark in "Disable Header Removal Compression...". The program only checks that setting at startup so exit MMG, then restart it. Now open your MKV file and Save it (if it used Header Removal Compression, the new file won't have it). See if that new file plays.
  7. Member Deblk's Avatar
    May 2012
    Yes am using the most recent version of MediaInfo.
    I have downloaded MKVtoolnix and checked the disable header removal compression and closed. Do I now have to add my file in MKVtoolnix and select muxing?
  8. Originally Posted by Deblk View Post
    Yes, after restarting MMG use the Add button to add your MKV file, then pess the Start Muxing button to create a new file.
  9. Member Deblk's Avatar
    May 2012
    Ok thanks. When I added the file it showed two entries would that be correct?
  10. Originally Posted by Deblk View Post
    Yes, the audio and the video.
  11. Member Deblk's Avatar
    May 2012
    Ok, this is outcome:
    General
    Unique ID : 194369698061164626725753843408929775964 (0x923A3DFF5C6D31098D03D4347AFB615C)
    Complete name : C:\Users\Debbie\Videos\tel10 (1).mkv
    Format : Matroska
    Format version : Version 2
    File size : 855 MiB
    Duration : 1h 26mn
    Overall bit rate : 1 386 Kbps
    Encoded date : UTC 2012-05-04 19:10:28
    Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
    Writing library : libebml v1.2.3 + libmatroska v1.3.0
    Video
    Format : AVC
    Duration : 1h 26mn
    Bit rate : 1 167 Kbps
    Width : 712 pixels
    Height : 356 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.192
    Stream size : 720 MiB (84%)
    Default : Yes
    Forced : No
    Audio
    Format : MPEG Audio
    Codec ID/Hint : MP3
    Duration : 1h 26mn
    Bit rate : 192 Kbps
    Default : Yes
    Forced : No
  12. Did your Blu-ray player play the new file?
  13. Member Deblk's Avatar
    May 2012
    Sorry have not had a chance to test it. All ready to test in morning, will let you know. Thanks for asking
  14. If that doesn't work about the only other thing I can see is the frame size. Some players require that the frame dimensions be integer multiples of 16. So 704x352 is more likely to play than your video's 712x356.
    Oh, one other thing: the profile is listed as Main@L5.1 although the level appears to be well below 5.1. Try changing it to 4.1 or 4.0 with a profile editor.
    http://coolsoft.altervista.org/en/h264leveleditor
  15. Member Deblk's Avatar
    May 2012
    Ok...will let you know hun...thanks again
  16. Member Deblk's Avatar
    May 2012
    I changed the profile to 4.1 then checked with MediaInfo and it was still showing 5.1....What do these profiles mean?
  17. What do these profiles mean?
    Profile&Level combination are ment to provide categories.
    These categories are ment so restrict the features used during encoding to ensure devices/decoders that content can be created in a way such that devices that are only capable to handle a restricted subset of these categories can handle the content.
    Overview of Profiles and Levels in H.264:
    http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Profiles
    http://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
    Cu Selur
    Ps.: changing the profile&level flags won't change the content of the stream, so if the stream uses a feature that needs High@4.1 changing it to Main@3.1 won't allow the content to be playable on a device that only supports content up to Main@3.1.
  18. Member Deblk's Avatar
    May 2012
    Thanks Selur for the info although I have to say this is far too complicated for me. I thought when buying the player it would play MKV files without all this fuffing about
    When I have done this I end up with 2 files...MKV and a BAK file. Do I have to copy both these files onto my USB or just the MKV? On my laptop I have set up VLC Player to play MKV files, would that make a difference if you get my meaning?
  19. Originally Posted by Deblk View Post
    You only need the MKV file. The BAK file contains a list of the changes the program made so restore the original data if necessary.
    That's odd. It should have shown the new profile@level. Are you sure you didn't make a mistake? Maybe changed or checked the wrong file?
    No, it doesn't matter what player you have associated with MKV files.
  20. Member Deblk's Avatar
    May 2012
    I have found the MKV file that plays
    General
    Unique ID : 193952070835471502887458916873769945754 (0x91E9CF62B33D88268306071C12B98A9A)
    Complete name : F:\Movie Library\Movies\Thriller-Sci-fi\Another Earth\ArEh11\ArEh11.mkv
    Format : Matroska
    File size : 697 MiB
    Duration : 1h 32mn
    Overall bit rate : 1 054 Kbps
    Encoded date : UTC 2011-10-29 03:43:19
    Writing application : mkvmerge v5.0.1 ('Es ist Sommer') built on Oct 9 2011 11:55:43
    Writing library : libebml v1.2.2 + libmatroska v1.3.0
    Video
    Format : AVC
    Format profile : High@L3.0
    Format settings, ReFrames : 5 frames
    Duration : 1h 32mn
    Bit rate : 863 Kbps
    Width : 720 pixels
    Height : 384 pixels
    Display aspect ratio : 1.85:1
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.130
    Stream size : 556 MiB (80%)
    Writing library : x264 core 119 r2106 07efeb4
    Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=863 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Duration : 1h 32mn
    Bit rate : 192 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 127 MiB (18%)
    Default : Yes
    Forced : No
    Changes below:
    What is format version?
  21. Member Deblk's Avatar
    May 2012
    I cannot change to the format profile from 5.1 to 3.1....I have tried TSMuxer and H264 Level editor and everytime I check with MediaInfo it stays at 5.1?
  22. Try a quick remux with mmg (add file, start muxing). Then see if h264 level editor can change the new file.
    The info you posted about the file that does play looks to use much higher profile settings than the file that doesn't play (regardless of what the profile@level flag in the header says). I suspect the problem is the non mod-16 frame size in the "bad" file.
    <edit> I did find an old MKV file that was version 1. h264 level editor had no problem changing the level. You did press the Change Level button, right? </edit>
  23. Member Deblk's Avatar
    May 2012
    MediaInfo still says 5.1 but when I add the file to H264 it shows 3.1
    Erm....yes, did press the change level button lol
  24. Member Deblk's Avatar
    May 2012
    I have changed to 3.1 by using TS in TSmuxing which shows as correct in MediaInfo. I am not sure what this file is now?
  25. All you're doing is changing a flag in the header. You aren't changing the properties of the video itself. But many players use that flag to determine whether they will attempt to play the video. Have you tried playing any of the modified files yet?
    TS is just another container. You might try using MMG to mux that TS to a MKV if your player doesn't support TS.
  26. Member Deblk's Avatar
    May 2012
    Have not tried the TS file as I did not think it would play. Did not realise I could mux that to a MKV file. Whats the best way to change the frame rate as you said I should try changing it to multples of 16 earlier?
  27. What program are you using to remux into TS? TsMuxer allows both TS and M2TS muxing. M2TS is the native container for Blu-ray so it may play.
  28. Member Deblk's Avatar
    May 2012
    I am using tsmuxer, will try M2TS
  29. Member Deblk's Avatar
    May 2012
    Woop Woop...this is what I did:
    The file that played before was a format file 3.0 so needed to get this result showing with MediaInfo
    I used TSMuxer and changed level with tsmuxing selected which created a TS file
    I then used MKVMerge to mux the TS file which created MKV file with the format file of my choice
    I am sure there is a much easier way but I did this with 2 files and they both worked. I have no idea why H264LevelEditor did not work as that would have been a much quicker solution
    Thanks guys for all your help and will now leave you in peace
