Hi everyone,
I`m having a problem with FFDshow. Up until rev4305, I had no issues playing any type of file format. But all the following versions after that rev make my .mts files out of sync. I have no issues with other file formats, just .mts. The files are not edited in any way, they are directly from my camera Panasonic DMC-TZ7, so this is not a editing issue, it`s a playback issue. I`m sure there`s a setting somewhere in FFDshow that can fix this, but can someone please point it out?
Thank you!
Edit: Received some support from the forums at www.ffdshow.info and a workaround would be this:
ffdshow video decoder -> decoder options -> disable "Detect soft telecine and average frame durations"
Results 1 to 1 of 1
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 21:21 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Audio/Video Sync Issue with .mts File Conversion
By arturo_morosoff in forum Video ConversionReplies: 2Last Post: 4th May 2010, 09:52 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 06:15 -
MTS Files
By krysia1974 in forum Newbie / General discussionsReplies: 1Last Post: 16th May 2008, 10:25
