I'm converting some DVDs using vidcoder, and this is perplexing me.
VidCoder says that the video file has a storage resolution of 720x480, and a display resolution of 640x480. It's most definitely a 4:3 video. Moreover, mediainfo says the same thing: 4:3 and 720x480. 720x480 is most definitely NOT 4:3.
What's up with this? Can't seem to find a good explanation.
The short version is DVD uses "non square pixels"
On playback, the media player resizes or stretches the display to square pixel equivalents
For example, 720x480 16:9 would be strectched to ~854x480 when played back
Some media players might play your 4:3 file as 720x540 (which is also 4:3 in square pixels, others might choose 640x480)
The encoded frame dimensions are 720x480 either way -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 00:36 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 11:15 -
Capture resolutions?
By visionman in forum Capturing and VCRReplies: 6Last Post: 28th Jan 2009, 12:13 -
Is optical media storage more stable than magnetic media storage?
By bevills1 in forum ComputerReplies: 24Last Post: 5th Apr 2008, 04:32 -
Really confused about resolutions....
By sam9s in forum DVB / IPTVReplies: 6Last Post: 12th May 2007, 12:42
