I'm trying to rip the subtitles off an anime DVD so I can convert them to srt and ssa/ass subs... Problem is that the disc has all four episodes in one title. 20 chapters, 5 each for four episodes. How can I go about ripping the subs to four separate files, each starting at 0:00:00?
Do you have the DVD on the hard drive already? If so, while there may be 5 chapters per episode, there might be one VOB ID per episode. If so, open the IFO for the episodes in PGCDemux, tick 'by VOB id' rather than the default 'by PGC' and check if each VOB ID corresponds to a full episode. If so, check the 'demux all subpic streams' box and demux them separately. If you're also reencoding the episodes, you might want the audio and video as well.
That will give you subs in SUP format. They can be OCR'd to SRT automatically in DVDSubEdit, or you can do an instant conversion to VobSubs (IDX/SUB) in SubtitleCreator for OCRing using something like SubRip.
Alternatively, use DVDDecrypter to get the episodes individually. Check only the chapters that correspond to the episode you want (in IFO Mode only, not the default File Mode). -
For whatever reason, that application is not demuxing the subtitle streams. It only does the one video and two audio streams. Log file says it doesn't even see any subs.
[General]
Total Number of PGCs in Titles=1
Total Number of PGCs in Menus=21
Total Number of VobIDs in Titles=5
Total Number of VobIDs in Menus=13
Total Number of Cells in Titles=21
Total Number of Cells in Menus=13
Demuxing Mode=by VOB Id
Demuxing Domain=Titles
Total Number of Frames=42492
Selected VOBID=2
Number of Cells in Selected VOB=5
Selected PGC=None
Number of Cells in Selected PGC=None
[Demux]
Number of Video Packs=425316
Number of Audio Packs=33376
Number of Subs Packs=0
Number of Nav Packs=2796
Number of Pad Packs=0
Number of Unkn Packs=0
[Audio Streams]
Audio_1=0x80
Audio_2=0x81
Audio_3=None
Audio_4=None
Audio_5=None
Audio_6=None
Audio_7=None
Audio_8=None
[Audio Delays]
Audio_1=-482
Audio_2=-482
[Subs Streams]
Subs_01=None
Subs_02=None
Subs_03=None
Subs_04=None
Subs_05=None
Subs_06=None
Subs_07=None
Subs_08=None
Subs_09=None
Subs_10=None
Subs_11=None
Subs_12=None
Subs_13=None
Subs_14=None
Subs_15=None
Subs_16=None
Subs_17=None
Subs_18=None
Subs_19=None
Subs_20=None
Subs_21=None
Subs_22=None
Subs_23=None
Subs_24=None
Subs_25=None
Subs_26=None
Subs_27=None
Subs_28=None
Subs_29=None
Subs_30=None
Subs_31=None
Subs_32=None -
OK, I didn't think to use DVD Decrypter to separate it into 4 separate VOB files using IFO mode. I looked at it, but it just didn't occur to me to uncheck the unnecessary chapters.
After doing that, I was able to use subrip to convert the text via OCR.
How can I determine TV show title/episodes? (re: VOB2MPG)
By sofakng in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Mar 2010, 13:50 -
Easy Add Subs to episodes
By KnightHeart in forum SubtitleReplies: 2Last Post: 22nd Jul 2009, 14:34 -
ripping dvd with episodes to media player
By pace508 in forum DVD RippingReplies: 9Last Post: 5th Nov 2008, 11:38 -
Ripping tv episodes from dvd to ipod?
By Steph-x in forum DVD RippingReplies: 3Last Post: 27th Jun 2008, 13:15 -
help with ripping the individual episodes from the dvd and converting them
By dvdrburner in forum DVD RippingReplies: 1Last Post: 22nd Aug 2007, 07:14
