I've been provided a .wmv video that has the video and audio out of synch.
When the video plays ourt-of-synch in Windows Media Player on my desktop (WindowsXP), AND when it's played in Windows MovieMaker, the sound of the person speaking on the video starts a bit before her mouth begins to move, and I need to adjust that.
How can I adjust that in Windows MovieMaker?
Thanks.
Moving you to our video editing section. You are not capturing anything.
Maybe will you learn something from http://www.youtube.com/watch?v=MD_dLxXSaB0
Or are you using windows live moviemaker? -
If it's a constant sync issue (e.g. like + or - 500ms the entire way through) , then you can shift the audio with asfbin
If it's a progressive sync issue (gets gradually worse as you play), then likely audio & video have different lengths and it's much more difficult to fix -
Thanks for the replies.
It's a constant synch issue, not one that progessively gets worse.
I could try asfbin, as suggested, but I'm trying to find out if this can be adjusted using Windows moviemaker (not live moviemaker). The suggested youtube link, talks about adding audio to video essentially.
So any moviemaker help would be appreciated.
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 22:59 -
Video and audio are out of synch when authored
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Dec 2009, 00:39 -
AVCHD audio and video are out of synch
By edong in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Jul 2009, 01:55 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47 -
WMV Conversion to Xvid - Audio Synch Problems Again
By TonyRomo1227 in forum Video ConversionReplies: 10Last Post: 6th Aug 2007, 17:32
