Hello I am Sorenson Squeeze 8 user, and please tell me what is "key frame" in H.264 codec. how many keyframes would be better for highest output video quality?
http://i.stack.imgur.com/9jsJr.png
It's the maximum number of frames before the encoder forces an I-frame placement
Read about GOP's, I, P B frames
http://en.wikipedia.org/wiki/Group_of_pictures
There is no "best" setting. Leave it as is unless you have a specfic reason to change it
For example, some devices and blu-ray require a shorter interval -
A key frame (I frame) is a frame encoded in its entirety, much like a JPEG image. Other frames (P and B) are "predicted", ie, they contain only the changes from frame to frame. Hence I frames are typically 10x larger than P and B frames, so the fewer you have (the longer the GOPs, group of pictures), the more compression you can get. But very long GOPs make the video harder to seek because the decoder has to locate the I frame before the requested seek position and decompress all the frames from that I frame to the requested frame before it can resume with playback.
Use this formula -> 10 * FPS
if source is 25 fps then use 250
if source is 60 fps then use 600
Avidemux: The beginning frame is not a key frame. Please move the A marker
By devilcoelhodog in forum EditingReplies: 13Last Post: 8th Jun 2015, 13:38 -
Key frame editing?
By vato76 in forum EditingReplies: 3Last Post: 7th Jun 2011, 13:55 -
Xvid4PSP key frame interval setting?
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 31st Dec 2010, 00:19 -
MainConcept H.264 frame rate issues encoding Final Cut output
By soandso in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 13:46 -
Virtualdub: the key frame displayed is off
By cheerful in forum Newbie / General discussionsReplies: 11Last Post: 19th Jun 2007, 13:28
