Hey guys,
I currently use fraps to record streams from Sopcast but I need the ability to record 2 streams at the same time. Preferably, I'd be able to record both streams from sopcast, since their streams are good quality.
Now I don't know if you can even play 2 streams in sopcast simultaneously, let alone record both.
Maybe I could record one stream from a normal flash player, and simultaneously record one from sopcast. Unfortunately the flash player streams aren't as good quality.
I have a high end PC so I don't think performance would be an issue - i5 2500k, 8GB Ram, Radeon 6950 2GB.
interesting. I didn't know about the record button nor the "allow more than 1 instance". I will try this out when I get home.
Thanks. -
Ok, so I loaded up 2 streams at the same time in sopcast, and hit record. But I can't playback the rendered file, except sometimes in windows media player. It's strange - it uses .asf format, but I can rarely play the file properly. I don't think sopcast is a good recording tool.
Anyone know if dxtory can record 2 streams at the same time? -
alright so I found a program called WMRecorder and according to the site it can record multiple video streams at the same time:
Anyone tried this program before?Unique Advanced Features
As you get to know WM Recorder, you'll appreciate these unique benefits:
- Automatic Recording
- Schedule live stream recording.
- Video and Audio File Converterfree with purchase!
- Turbo Recording - record streams at up to 10x speed.
- Record password protected videos.
- Record at the highest quality.
- Works with slow dial-up connections.
- Record multiple streams at once.
- Resume recordings.
- Split and merge recordings with the included Converter.
- Watch commercial free from some popular TV/Movie sites.
- Preview, pause and rewind live streams.
- Automatically reconnect for recording on-demand broadcasts.
- Includes the handy Loopback application to record more sites..
- And more!
Yes. WM Recorder allows up to 200 entries to be queued up for recording. The actual number of simultaneous recordings depends on your connection bandwidth. A cable connection usually supports 10 to 20 simultaneous connections. For example, YouTube videos are streamed at approx. 500 kbps. With a cable connection of 10 Mps bandwidth you can record 20 videos simultaneously. Some
web site don’t allow more than two simultaneous downloads.
Even if WM Recorder worked with p2p tv I think it would capture the asf stream like SopCast, you could try to repair the files with Asfbin. I'm also guessing they might get corrupt if your upload speed can't keep up with your download speed, especially when you're watching more than one stream at the time.
Record Periodically Live Streams
By npadgett in forum Video Streaming DownloadingReplies: 0Last Post: 13th Oct 2009, 18:21 -
Noob Question: TV tuner that can record OTA HD streams?
By peggypwr1 in forum Newbie / General discussionsReplies: 14Last Post: 8th Oct 2009, 19:30 -
How to record live radio and video streams?
By Shadowofthedarkgod in forum Video Streaming DownloadingReplies: 8Last Post: 15th Aug 2009, 20:40 -
How do i record CNN Live video streams?
By quantass in forum Video Streaming DownloadingReplies: 4Last Post: 13th Sep 2008, 12:44 -
No one can see my stream using SopCast
By Nitro89 in forum Video Streaming DownloadingReplies: 11Last Post: 26th May 2008, 12:08
