I've asked this question in other forums and haven't gotten an answer so here goes.
I shoot a lot of video of reenactments and then add effects to make the footage look old (greyscale,grain,lines,ect). My camera of choice is a Canon sd1000,which shoots at 15 frames per second at 4:3 aspect. Cameras like this have pretty much disappeared from the landscape. The closest I can find is an hd camcorder that shoots 24p. So, my question is, how can I: A)convert 16:9 footage to 4:3 with out adding the very noticeable black bars on the sides of my video? And, B) How can I drop frames to make it look like it was shot at 15-16 frames per second. Essentially,I'm trying to make my footage look like it was shot between 1900 and 1925. All of my NLEs have an export option of QVGA, but the image size is smaller than 640 x 480. but it does export at 15 fps. Any ideas on how to get the effect I'm looking for? Thanks for any help you can give.
mencoder/mplayer with 'filmdint' and 'io=' option should to the trick,.. see: http://www.mplayerhq.hu/DOCS/man/en/mplayer.1.txt
(assuming you got some basic knowledge how to use mencoder) -
Converting from 16:9 to 4:3 doesn't add black bars to the sides. It adds them above and below. Maybe you meant converting 4:3 to 16:9?
Either that or you crop away active video from the sides to go from a 1.78:1 ratio to 1.33:1.
AviSynth's ChangeFPS command is one way:B) How can I drop frames to make it look like it was shot at 15-16 frames per second.
ChangeFPS(16)
http://avisynth.org/mediawiki/FPS
Changing audio frame rate?
By architectofpain in forum AudioReplies: 22Last Post: 5th Apr 2013, 10:27 -
Changing DVD Frame rate
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 7Last Post: 28th Dec 2011, 19:58 -
Frame rate conversion in Linux
By lovyagin in forum Video ConversionReplies: 12Last Post: 8th Nov 2011, 09:37 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
