Well I've been doing some searching on how to open up flv files inside Virtual Dub and on another forum someone suggested to try using the 'ffmpegsource' plugin with avisynth. So far I've just been getting errors in trying to get Vdub to open or read the .avs script I've made. Ive tried using this code in the script file.
I've tried moving files and using other code but to no avail. These are the files I have that came with the plugin: FFMS2.avsi, fmsindex.exe and ffms2.dll. Link here: http://code.google.com/p/ffmpegsource/downloads/detail?name=ffms-2.17-cplugin.7z&can=2&q=Code:A = FFAudioSource("c:\sample.flv") V = FFVideoSource("c:\sample.flv") AudioDub(V, A)
What am I doing wrong? Is there configurations I have to do in ffdshow (I have K-llte codec pack) And is ffmpegsource a good plugin for flv files?
Other questions:
1. Are the term filters and plugins the same thing?
2. What are the main differences between Virtual Dub and AviSynth?
3. I've read something about having to register AviSynth plugins using the regsvr32 command. Can somebody fill me in on what this does?
That is the C version of the plugin (see 'Versions and variants' here) and the dll has to be loaded explicitly using LoadCPlugin(). You would be better using the 'vanilla' version (here) which will be loaded automatically by Avisynth if placed in the plugins folder.
ffmpegsource is completely independent of ffdshow - it has its own version of ffmpeg built-in.Is there configurations I have to do in ffdshow (I have K-llte codec pack) And is ffmpegsource a good plugin for flv files?
It's probably the best source filter for flv files.
A filter is a general term for a function that processes video and/or audio, and Avisynth provides many built-in filters. A plugin is an extension provided by a third party which adds additional filters.Other questions:
VirtualDub is an editor with a GUI while Avisynth is a frame server controlled by scripts
http://avisynth.org/mediawiki/Main_Page
Avisynth plugins don't need to be (and should not be) registered.
They are never used directly by the OS and are loaded only by Avisynth.
http://avisynth.org/mediawiki/Plugins -
I've had some success with this:
http://home.comcast.net/~fcchandler/Plugins/FLV/index.html -
Gavino, just want to say thanks for answering all my questions. I meant to do it earlier but have been busy these past few days.
hech54, thanks, I'll check that out.
Virtual Dub converted files poor quality.
By stark88 in forum Video ConversionReplies: 4Last Post: 8th May 2011, 23:39 -
Can't edit MP4 files in Virtual Dub
By brevardo in forum EditingReplies: 25Last Post: 10th Mar 2011, 21:18 -
Virtual Dub editing MP4 and WMV files with new plugin
By brevardo in forum EditingReplies: 5Last Post: 14th Jan 2011, 12:26 -
Queue files in Virtual Dub Mod?
By leogeo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 03:13 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 17:21
