So, I have a Panasonic PV-GS300 digital tape video camera. When watching back the tape on the camera flip out monitor screen and/or watching video from hard drive during editting, the quality is great.
But I was watching my finished product on my tv and whenever the video is of action, moving left or right, such as following a runner in a little league game, the video quality gets all checked and poor. Again, but not while watching the original tape in the camera. So I imagine it's something I did or didn't select during editting or burning?? Appreciate any help.
Probably not enough bitrate
Can you list the settings and software used? -
When I select a downloaded segment of home video to add to an editting project it shows a pop up box giving video specs, which read, video bit rate: 248583168, AVI format,
frame rate 29.970030 fps,
media size 720 x 480,
aspect ratio 16 x 9.
I used: Roxio Easy CD and DVD Creator 6 "DVD Builder". I can use the cameras software that came with it to download. But it does not have a disk burning ability. So I just use the old Roxio software for downloading, editting and burning phases. -
What you want to look at is the bitrate of the encoded video for the DVD , not the source file
If you use too low a bitrate there will be lots of pixellation or macroblocking, most noticable on scenes with action. See if you can raise it in your software (there will be limit for DVD-Video) , or use other software -
Thank you. At least I know what to focus in on now. Yes I believe the advanced settings options on the software is very limiting. I look in to it.
How to remove video blur?
By Djard in forum Newbie / General discussionsReplies: 10Last Post: 27th Aug 2010, 00:38 -
Blur
By jfreak53 in forum EditingReplies: 3Last Post: 24th Apr 2010, 16:22 -
can HD or Blur Ray be recorded?
By Ade007 in forum DVD RippingReplies: 4Last Post: 11th Feb 2008, 19:22 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 08:52 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 11:49
