By mistake I update my sony BDP S185 to the newest version, which contain cinavia, and this was a nightmare, as several discks was showing the buggy note mute note. Sony did not allow the downgrade of the firmware, nor the hard reset to the factory firmware.
I then found out that using the "easy downgrade.exe from Windows binaries, which can be found at this link to work.
http://www.malcolmstagg.com/bdp-s390-downgrade.html
which needed to be extracted in a folder, then into the same folder extract your update version, and change the date and version to a newer one that currently installed
the only problem was that the provided updted was going back only to M09.R.0033, which still contain cinavia, but I found earlier version in the interner, which does not: M09.R.0028 at this link: http://www.touslesdrivers.com/index.php?v_page=23&v_code=32656 burned to a CD and (SOLVED)
Results 31 to 31 of 31
Sony BDP-S380 - What will it do?
By THRobinson in forum DVD & Blu-ray PlayersReplies: 17Last Post: 29th Mar 2012, 03:25 -
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 17:12 -
Sony BDP-S380
By ocmorph in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Oct 2011, 11:27 -
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 03:03 -
Sony BDP-S370: Firmware upgrade to 567 and region free hack
By Nosh3 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 19th Jan 2011, 08:57
