Can anyone advise please (apart from suggesting throwing it in the rubbish bin)
I bought a Eurotech dvd-d4001 recorder for ten pounds its very old but looks very clean, i.e. looked after.
It has no remote or instructions, just the power cable, but I thought that I would take a chance.
using a scart cable, I plugged it into an old tv that I could afford to have blow up, inserted both "Find Remo" and a home produced music cd and got brilliant results.
I would now like to see if I can get it to record, but I am a bit (lot) lost concerning this, what other cable would I require, I've tried googling for a remote, but without success, can anyone help please?
tia
Buy a logitech 300i and use that to program your dvd recorder.
Thanks for your prompt reply johns0, as I said in my query, there are no instructions with this recorder, do you think that the logitech 300i will find the recorder if I have no information about it other than whats on the front of it i.e. "eurotechdvd-d4001" there is no model number or serial number on the back either?
Thanks again. -
Theres a good chance but i cant guarantee it.
o.k. johns0, thanks, I think I might try and get some info from logitech, but have not been too impressed with them replying in the past.
I will come back and let you know if I get a result, thanks for your trouble.
o -
I seee you are in UK. Why not look at the remotes they sell in shops like Poundland for £1. These can be set up to operate many devices but often do not have the latest models. Hopefully you will then be able to check your recorder works with little extra cost.
Hello itsonlyme (why didn't I use that?).
I'm going to give that a shot, why not? nothing to lose! I will come back if there is any result,
thanks.
sony dvd recorder remote problem
By tattoojo in forum DVD & Blu-ray RecordersReplies: 10Last Post: 29th Apr 2015, 21:03 -
EuroTech DVDR 4001 DVD Recorder.
By classicfilmbuff in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Apr 2012, 17:34 -
any way to record from TV to DVD recorder?
By thedriver2200 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 10th Jun 2008, 13:37 -
DVD recorder that doesn't require remote
By Knightmessenger in forum DVD & Blu-ray RecordersReplies: 13Last Post: 27th Nov 2007, 00:51 -
DV-DS81E hitachi DVD recorder universal remote code needed
By Dekaspace in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jul 2007, 12:28
