Hi, over the past year to 18 months I have been slowly ripping my DVD's to my iMac, first by using 'MacX DVD Ripper Mac Free Edition' and then using 'Handbrake' to convert it to be played in my iMac. I then use my Apple TV to stream this to my TV. This has been working fairly well for the past year or so, but I feel that its not as good quality as it would be by playing the actual DVD in a DVD player. I understand that some quality will be lost, but I'm not sure if there is anything else out there that is a better solution whereby not so much quality is lost. Also are there any 1 step solutions? It seems to be a 2 part thing at the moment.
I'm also in a situation where I have a growing blu-ray collection and not able to do the same thing. What software can I use to get blu-ray off the disk and in a playable format to stream over to my Apple TV?
I'm assuming I'll need some sort of external blu-ray reader/writer as my Mac only has a DVD reader/writer?
One last thing, I'm also considering getting a 5.1 surround sound system for my lounge TV. Would all the surround sound effects still work like the would playing a DVD/Blue ray in a player?
Sorry for the amount of questions - there is so much to find out!
Results 1 to 10 of 10
Unfortunately your question really needed to be asked in our Mac forum as it is Mac specific. Try to change your subject as quickly as you can to something like "Ripping blu-ray on Mac". You need to let the Mac people know that this is really a Mac specific issue. The vast majority of us use Windows rippers for Blu Ray. I have no idea if Mac even has a BD ripping tool or how good it is.
Your first problem is your using Mac, Mac users just don't have the same type of software/hardware available to them as windows users, but to answer you questions.
Most people can not tell the difference between a well done conversion and the original source, I would say as much as 85% of people can't tell the difference. There is most likely something wrong with the settings you are using. I would recommend using CQ of 22 for DVDs, 18 for BD titles. Or better yet switch to Ripbot264, imho it produces better audio and video (not an option for mac OS).
You are doing two steps, ripping and converting. Do you mean 1 click solution?
Handbrake does have an option to convert from the disk on the fly as long as the disk is not encrypted or you have AnyDVD installed (not an option for mac.). For 1 step solutons on a Mac i think , DVD Fab Dycrypter or DVD Fab HD Dycrypter are you only options, they will handle both ripping and encoding. But imho these tools create a noticeably softer video.
You can try DVDFab HD Dycrypter to rip BD titles. In recent years the Mac has officially started to support BD drives you shouldn't have a problem finding a drive, check Macsales.
On my PC i have no problem doing this, I assume the same can be done with appleTV check you user guide for supported audio formats. You can also try setting up a virtual machine running windows, this will allow you to circumvent some issues.Last edited by dragonkeeper; 30th Apr 2012 at 12:32.
Murphy's law taught me everything I know. -
Moved to the mac forum where you can get more help.
Wow! Thank you all for you're very helpful and detailed responses - your very informative! Perhaps I will check my settings as there is a noticeable difference between the actual DVD and the ripped version. Especially on a scene where the is a lamp on in a dark room, the graduation from white to black looks quite blocky - if that even makes sense!
Yes that makes sense, sounds like the bit rate was to low. Use media info on the file and post the details here.
Try Pavtube.com. They have several Bluray ripping tools that work very well. Pavtube Bluray ripper, Pavtube Byte-copy, and Pavtube video converter all work as advertised and I use them everyday on my iMac.
Basically the situation is this - you need a cable box that allows video out over firewire and actually has a firewire port. Some do not. For example the current AT&T Uverse boxes do NOT have a firewire port at all. It is true that on a Mac that if your cable box has a firewire port it should just work with nothing special to do, although you will need to install a freeware program to control the actual capturing and do any scheduling you need. If you have 32 bit Windows, it's trivial to find and install the drivers to do this kind of firewire capturing but all cable boxes are not supported. It's a bit of a crapshoot there. And 64 bit Windows is not supported at all for this and probably never will be. The original author of the 32 bit Windows drivers has abandoned the project and nobody else has been able to produce working 64 bit drivers, including some who where actually hired to do the job.
My understanding is that in Canada the cable boxes do not support firewire at all so this won't work there no matter what computer you have.
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping application for blu-ray
By pcb in forum Blu-ray RippingReplies: 2Last Post: 24th Apr 2010, 22:21 -
Ripping Blu-ray for PS3
By BritishBeef in forum Blu-ray RippingReplies: 9Last Post: 25th Oct 2009, 10:55 -
Blu Ray Ripping help
By ShinjiIkari1990 in forum Blu-ray RippingReplies: 2Last Post: 22nd Jun 2009, 23:10 -
Ripping a Blu-ray
By ma2kp in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2008, 22:53
