I'm running Win 7 64 bit btw.
				Results 91 to 120 of 270
	I presume you meant 4.
 No crash!
 Code:Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\Alan>"C:\Program Files\Hybrid\ffmpeg.exe" -threads 8 -v -10 -y -i "C:\ Users\Alan\AppData\Local\Temp\The Chronicles of Narnia test - 1 audio - 5 subs- Hybrid DELAY -33ms_eng_aid_0__10_47_49_701_02.ac3" -ac 2 -acodec pcm_s16le -f w av - | "C:\Program Files\Hybrid\fhgaacenc.exe" --ignorelength --vbr 4 - "C:\Use rs\Alan\AppData\Local\Temp\The Chronicles of Narnia test - 1 audio - 5 subs-Hy brid_eng_aid_0__10_47_49_701_05.aac" C:\Users\Alan>
	that's not the 3rd call  the 3rd call does not have the '-v -10' the 3rd call does not have the '-v -10'
 Cu Selur
	I did the 3rd call in my earlier post. (#90)
 I just did it again anyway and it crashed again!
 Code:Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\Alan>"C:\Program Files\Hybrid\ffmpeg.exe" -threads 8 -y -i "C:\Users\Al an\AppData\Local\Temp\The Chronicles of Narnia test - 1 audio - 5 subs-Hybrid DE LAY -33ms_eng_aid_0__10_47_49_701_02.ac3" -ac 2 -acodec pcm_s16le -f wav - | "C: \Program Files\Hybrid\fhgaacenc.exe" --ignorelength --vbr 4 - "C:\Users\Alan\App Data\Local\Temp\The Chronicles of Narnia test - 1 audio - 5 subs-Hybrid_eng_aid_ 0__10_47_49_701_05.aac" ffmpeg version N-40301-gc1fe2db Copyright (c) 2000-2012 the FFmpeg developers built on May 3 2012 11:44:06 with gcc 4.6.3 configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable -libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable- libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e nable-zlib libavutil 51. 49.100 / 51. 49.100 libavcodec 54. 17.101 / 54. 17.101 libavformat 54. 3.100 / 54. 3.100 libavdevice 53. 4.100 / 53. 4.100 libavfilter 2. 72.104 / 2. 72.104 libswscale 2. 1.100 / 2. 1.100 libswresample 0. 11.100 / 0. 11.100 libpostproc 52. 0.100 / 52. 0.100 [ac3 @ 00000000003af540] max_analyze_duration 5000000 reached at 5024000 [ac3 @ 00000000003af540] Estimating duration from bitrate, this may be inaccurat e Input #0, ac3, from 'C:\Users\Alan\AppData\Local\Temp\The Chronicles of Narnia t est - 1 audio - 5 subs-Hybrid DELAY -33ms_eng_aid_0__10_47_49_701_02.ac3': Duration: 00:02:15.10, start: 0.000000, bitrate: 192 kb/s Stream #0:0: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s Output #0, wav, to 'pipe:': Metadata: encoder : Lavf54.3.100 Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16 , 1536 kb/s Stream mapping: Stream #0:0 -> #0:0 (ac3 -> pcm_s16le) Press [q] to stop, [?] for help C:\Users\Alan>
	Okay, to be sure I understood you correctly you tested the 32bit AND the 64bit version and both crash on your system with 'call 3.', right?I just did it again anyway and it crashed again!
	I just read your post again - do you want me to also download the 32 bit version?
	Sorry, we both posted at the same time - will get the 32 bit version now.
	Sorry for the misunderstanding!
 I got the 32 bit version and ran call 3.
 No crash!
 Still got some yellow text in the command window though. I put it in bold below.
 Code:Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved. C:\Users\Alan>"C:\Program Files\Hybrid\ffmpeg.exe" -threads 8 -y -i "C:\Users\Al an\AppData\Local\Temp\The Chronicles of Narnia test - 1 audio - 5 subs-Hybrid DE LAY -33ms_eng_aid_0__10_47_49_701_02.ac3" -ac 2 -acodec pcm_s16le -f wav - | "C: \Program Files\Hybrid\fhgaacenc.exe" --ignorelength --vbr 4 - "C:\Users\Alan\App Data\Local\Temp\The Chronicles of Narnia test - 1 audio - 5 subs-Hybrid_eng_aid_ 0__10_47_49_701_05.aac" ffmpeg version N-40301-gc1fe2db Copyright (c) 2000-2012 the FFmpeg developers built on May 3 2012 11:40:38 with gcc 4.6.3 configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable -libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable- libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e nable-zlib libavutil 51. 49.100 / 51. 49.100 libavcodec 54. 17.101 / 54. 17.101 libavformat 54. 3.100 / 54. 3.100 libavdevice 53. 4.100 / 53. 4.100 libavfilter 2. 72.104 / 2. 72.104 libswscale 2. 1.100 / 2. 1.100 libswresample 0. 11.100 / 0. 11.100 libpostproc 52. 0.100 / 52. 0.100 [ac3 @ 0200c500] max_analyze_duration 5000000 reached at 5024000 [ac3 @ 0200c500] Estimating duration from bitrate, this may be inaccurate Input #0, ac3, from 'C:\Users\Alan\AppData\Local\Temp\The Chronicles of Narnia t est - 1 audio - 5 subs-Hybrid DELAY -33ms_eng_aid_0__10_47_49_701_02.ac3': Duration: 00:02:15.10, start: 0.000000, bitrate: 192 kb/s Stream #0:0: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s Output #0, wav, to 'pipe:': Metadata: encoder : Lavf54.3.100 Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16 , 1536 kb/s Stream mapping: Stream #0:0 -> #0:0 (ac3 -> pcm_s16le) Press [q] to stop, [?] for help size= 25332kB time=00:02:15.10 bitrate=1536.0kbits/s video:0kB audio:25332kB global headers:0kB muxing overhead 0.000177% C:\Users\Alan>
	What CPU do you use on your system?I got the 32 bit version and ran call 3.
 No crash!
 Seems like ffmpeg has some problems with it.
 that's no problem,..Still got some yellow text in the command window though. I put it in bold below.
 -> try if the encoding that crashed before now works if you use the 32bit ffmpeg in your Hybrid folder.
 Cu Selur
	It worked!
 I am running a longer one right now with 3 audio tracks and 4 subtitles and it seems to be going nicely - still busy processing though.
 My processor details are under my name: Intel i7 2600K
	The longer video ran okay, but no file was saved.
 I am trying to post the debug, but it won't upload. Will restart my browser and try again!
 Must be something with ffmpeg and my processor. It is a very popular processor so I am surprised. Can you report it to ffmpeg so they can fix it?Strange on my i7 875k the 64bit version runs fine,..
 Should I just carry on with the 32 bit version for now?
 Does it matter that it is not in the x86 folder?
 I presume that when you post an update I will have to also download the 32 bit version of ffmpeg if it crashes again or should I just use the 32 bit version of Hybrid?
	Yes you would have to use a 32bit Version of ffmpeg until the bug is fixed,.. (will report it later if I find the time)
 No, that's no problem.Does it matter that it is not in the x86 folder?
 Cu Selur
	Nope, the debug file won't post! Some background backup is running so I will wait for it to finish first and then restart the PC.
	Okay - I restarted and ran a different file with 2 audios and 2 subs. No file was saved!
	There's a problem with the language detection -> I'll look into it,..
 language detection works fine, mkvmerge just doesn't support 'iw' as language,.. (should be 'he' -> will add a workaround)Last edited by Selur; 7th May 2012 at 08:17.
	Froze how?
 Judging from the log the subtitles, were extracted, autocrop ran and the gui should be enabled again,...
	It just stopped processing after the log on the main screen got to the last line below:
 The program still responds, but the job queue is empty. The 2 audio tracks and the 2 subtitles still appear in the relative lists, but no further progress happens.Code:Adjusting audio delay from 0 by 33 to -33 due to encoder compensation. Adjusting audio delay from 0 by 33 to -33 due to encoder compensation. Adjusting audio delay from 0 by 33 to -33 due to encoder compensation. Adjusting audio delay from 0 by 33 to -33 due to encoder compensation. extracted subtitle F:\My Videos\Mede8er\Working\Hybrid\Finding Nemo (2003)_id_3_iw_default.idx extracted subtitle F:\My Videos\Mede8er\Working\Hybrid\Finding Nemo (2003)_id_4_iw.idx
 If I then try to add the title again, I get 2 windows opening saying:
 The other window says the same thing but with "value: 1"Code:EnableGUI value should not be > 0! value: 2 Please create a debug output of the whole thing and report to Selur.
 After clicking OK, I have to close the program as it will do nothing else.
	Why should there be anything in the job queue? You didn't press 'Add to queue',..The program still responds, but the job queue is empty.
 That should not happen,.. -> I can reproduce this -> looking into itIf I then try to add the title again, I get 2 windows opening saying:...
 -> send you a new version,..Last edited by Selur; 7th May 2012 at 10:04.
	I did press add to queue just prior to clicking Start Queue.You didn't press 'Add to queue',..
	than you uploaded the wrong debug output,..  Because the one you posted last does not contain any job generation&o. Because the one you posted last does not contain any job generation&o.
 Cu Selur
	You are correct. The program froze while reading the file just after I dropped it on Hybrid.
 Silly me. I have been doing this so much now that I am starting to go on automatic and not paying attention!
 It just did it again with the latest versions installed as per your last PM.
 I didn't get the GUI error though.  Last edited by Ahari; 7th May 2012 at 12:02.
	What is the last thing written in the Log shown on the Main-Tab ?
 I'm unsure if the 'freezing' you describe is just Hybrid i.e. extraction or analyzing something or if it is a bug,.. (btw. disabling the debug output should speed up the normal responsiveness of Hybrid, since no hdd access for writing the debug output to hdd is necessary then)
 Cu Selur
	Selur, I have to apologise! The program now works absolutely perfectly!
 In fact on my machine it really rocks - Even with my rather heavy demands for quality I am getting 80-100fps processing on some files and about 50fps on average!
 I feel like an idiot. It was me that was freezing! I spent so long not getting past the initial reading of the files that I totally forgot to add the job to the queue!! What an twit!! What an twit!!  ! !
 You fixed the subtitles problem with the last version and it now works perfectly! I just have to play with the settings and get it to do what I want regarding file sizes, quality, etc... I just have to play with the settings and get it to do what I want regarding file sizes, quality, etc...
 A small suggestion - would it be possible to put a simple line in the main page log to tell the user when it has finished reading the file? Something like: "Finished reading files ..." or "Done reading, what do you want to do now?" Sometimes it is so fast, I wait in case it has something else to do and on other files it takes a little longer and I try to carry on when it has not done its thing!
 Thanks for the PM'd update - I thought I would reply here so everyone can see what a great program this really is!
 You have done an amazing job with this piece of software and have been very patient with my noob questions and problems.
 You have gone way out of your way to fix every one of my issues and I really am soo grateful. You definitely have a new fan!
 Question: I presume that if I want to do any kind of cropping and or resizing, that I must deinterlace first. Does Hybrid automatically do it in the correct order? ie: deinterlace first. I assume bobbing is better?
 You also mentioned using some filters on almost every job you do. Can you refresh my memory on which ones to use and why do you use them?
  LaCinema Mini HD Connect cannot play MKV H.264 files ?By centrino3 in forum Newbie / General discussionsReplies: 12Last Post: 12th Aug 2011, 10:45
  How to convert an h.264 MKV with softsubs to an h.264 MP4 with hardsubs.By hawk16zz in forum User guidesReplies: 4Last Post: 27th Apr 2010, 12:41
  H.264 TS files created using HD PVR to MKV.By Red Hat in forum Video ConversionReplies: 223Last Post: 19th Nov 2009, 16:35
  Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a MacBy iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 17:50
  Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subsBy Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
