Thanks.
Only one question, I have input file in that American/Japan 59,94p file.
Do you think, the described script will work also with this my progressive 1280x720 MP4/MKV file as input ?
Personnaly, I do not like interlaced output. Even highest framerate 60i/50i HD output from editor produces to me mini flickering contures + mini bluring when camera panning or zooming or filmed subjects are in movement.
Results 211 to 237 of 237
Here is one sample, which I would like to convert to 25i PAL format, as a DVD copy for my old parents.
"But you said you don't like interlaced output, no? "
Hello, yes, but only for HD resolution.
In 576 resolution it makes no problem for me, both 25p or 25i are OK.
25i (bottom first) is standard for PAL, if I am not mistaken.
I have HD for Bluray (720p/59,94) for me, and for my parents I want (older) DVD in standard PAL res. (576 lines,25i) -
Yes, I opened in Avidemux even the original raw 60p clip from FH1 Xacti camcorder, and each second frame is like the duplicate.
Anyway, the question remains the same. Will the described script will work also with this my progressive 1280x720 MP4/MKV file as input ? Now I know, it is propably re-calculated 60p (from 30p chip?) and not natural 60p format. -
I would reduce the frame rate from 60 fps to 30 fps before using motion interpolation. So for 25 fps progessive PAL your script will look something like:
But be aware that SmoothFPS2() (and all the other variations you'll find) sometimes generates annoying artifacts.Code:Import("C:\Program Files (x86)\AviSynth 2.5\plugins\SmoothFPS2.avs") Load_Stdcall_plugin("C:\Program Files (x86)\AviSynth 2.5\plugins\yadif.dll") DirectShowSource("circus.mp4") SelectEven() #or SelectOdd() LanczosResize(720,576) SmoothFPS2(25,1) -
And you can also try to get the script to make just 30fps progressive DVD (HCencoder), I sent 30fps NTSC DVD to Europe and they never had a problem with it:
mvtools2.dll might fail at crossfades, during fast movements etc., so you might try this alternative also if you change that fps after editing ....Code:DirectShowSource("circus.mp4") SelectEven() #or SelectOdd() LanczosResize(720,480) -
Please upload a sample from the outcome. I am buying this camcorder this or the next month, I would like to see what you can achieve!
I am very impressed anyway, this sample plays fluently on my slow computer. It is very nice even though it is inside with lamp. I like this video. Interestingly the files of my older Sanyo HD1000 don't play this smooth by far. -
Circus.m2v seems to play smooth enough,thanks.
NTSC DVD I will not risk for my friends, though in my DVD own standalone player NTSC works OK.
I was trying it.
As for playing circus.mp4 on week PCs, the clue is in that, that the output from editing SW must be set for the "lowest" 720/60p profile for AVCHD stream according Bluray standards. That is result of my many testings. Check via Mediainfo program (Main@L3.2). If it even then makes problem, it is good, for instance, to pass the stream through Avidemux from mp4 to mp4 file (without re-encoding).
In these days, I would not buy Xacti FH1/HD2000. I would go at least for Panasonic HC-V707 (if not directly 3MOS-chipped HC-X800/900, 3D of them not necessary) though more expensive, but maybe next year not so. The old Xacti HD1000 can still serve good and make satisfactory results, if you know how handle it and postprocess its material for Bluray HD (or MKV HD stream on PC etc). Those better Panasonics will be requiring stronger PCs + suitable SW, I suppose. -
I am not a video enthusiast, just somebody who would like to make some nice shots, and the problem is that the video color of most of the camcorders doesn't inspire me. The Sanyo was the only type that, after purchasing it and making test videos, really caught my attention. That was the first camcorder in case of which I said: wow. Simply because the colors are so nice, just as I like it, and there are nice details. I know this camcorder is just an junior among other big guys in the market, but this is the only brand where the output really inspire me. At least on this price level. I only found 1 other brand that would interest me, the Canon HV40, but I have no firewire port on any of my laptops, so I couldn't use it, and it is also much more expensive than a Sanyo.
I respect the Panasonic brand anyway, because they make lots of good, technically advanced stuff on affordable price, but for me the color output seems cold. I don't like it that much. The Sanyo has warmer colors. And I like it. JVC is close to this in colors, but I am not sure the optics are competitive in those JVC consumer camcorders with the Sanyo. One thing is sure, in the Sanyo, there is a big lense. I am not sure about the JVC. -
I have tryied, aomething wrong with this my Avs script:
DirectShowSource("VELIGRAD2011.MP4", seek=false)
AssumeTFF()
AssumeFPS(30000,1001)
Trim(0,10497)
Yadif(mode=1, order=1)
SmoothFPS2(50,1)
SeparateFields()
SelectEvery(4,0,3)
Weave()
Everything went fine, no artifacts, no jerking, but PAL stream in SLOW MOTION.
Duration of outputed "standard res." m2v file took exactly 2 x more time than inputed "HD res."mp4.
Any idea how to speed up the resulted video stream please? -
DirectShowSource() is unreliable -- it may return the wrong frame rate. AssumeFPS(30000,1001) may not be right for your video. You have to provide a sample clip...
As well as what jagabo said, note that
- Trim(0,10497) was specific to a particular Bencuri source and is probably not wanted at all here;
- Yadif should only be used if your source is interlaced (your circus.mp4 wasn't). -
I am providing my sample which I use as input MP4 video in attachment.May I have also one more avs script for such a squeezed PAL output?-second attachment JPG. I like when modern 16:9 tv screens stretch such picture when playing from DVD player, I do not like letter boxes etc. Thanks
Leave off the Yadif, the AssumeFPS, and the Trim lines from your script. Your video is already 59.94fps to begin with.
Learn to enjoy the videos in the aspect ratio they were created and the one in which they were meant to be seen. Learn to ignore the letterboxes and pillar bars. Why spend so much time getting the encoding right when you'll go and wreck it anyway when watching it? Having said that, this video is meant to fill the whole screen of a 16:9 TV set. Encode it as 16:9 and not as 4:3 as shown in your picture. And as mentioned before, don't use DirectShowSource if you can possibly avoid it. Use FFVideoSource:I like when modern 16:9 tv screens stretch such picture when playing from DVD player, I do not like letter boxes etc.
http://code.google.com/p/ffmpegsource/ -
The script for that source can be reduced to:
You might be slightly better results putting SmoothFPS() before LanczosResize(), but it will take longer to render.Code:Import("C:\Program Files (x86)\AviSynth 2.5\plugins\SmoothFPS2.avs") ffVideoSource("VELIGRAD2011.mp4") LanczosResize(720,576) SmoothFPS2(50,1) SeparateFields() SelectEvery(4,0,3) Weave() -
Thanks for tip about FFVideoSource. Finnaly I retourned to DirectShowSource.
But please I have met a problem.
The converting of short clips no problem. But if I am trying to convert the whole 3,55 Gb high.def. input, it always allows me to convert only first 3 minutes of PAL stream. Nice picture of m2v, but only cca first 10 percent of the whole movie. Is not HCenc. encoder limited somehow please? -
Did you press the button : "Convert: All Frames" on the first settings panel? If not, it might happen the software is set to the amount that was present in your test clip. Check that.
You didn't remove the Trim(0,10497) command from the script. That command limits the number of frames to 10497, about 3 minutes at 60 fps. The Trim() command was necessary with Bencuri's source because DirectShowSource() misidentified the source frame rate and number of frames.
Hi Bencuri,
I already have ProdadMercalli stabilisation utility, tried some experiments, and for some cases it can solve stabilization, especially, if you work with SD resolution clips (me not, I want BluRay compatible disc HD outputs). Imperfectness of electronic stabilisation I am preventing already in the moment of shooting. Either from (mini) tripod, or simply lean the camera on wall, tree etc. Rather with wide lens angle then narrow, of cource. An not necessary zooming and camera moving. Movements must be in front of camera. The FH1 suffers also with rolling shutter effect, as all CMOS chip cameras. But very rarely, depends on the scenery shots, I have met it only twice during 2 years, it is almost nothing. Another imperfectnes is purple firing effect/chroma abberation, which is due to the camera large lens, which on the other hand, enable good picture in worse light enviroment. It can be seen more offen, e.g. in series of videoshots under very cloudy heaven, or sometimes when zoomed to far situated details. For this I use process, something like this: http://photography-on-the.net/forum/showthread.php?t=1030919
And it works very fine.
60fps video playback on YouTube
By Chipango in forum Video Streaming DownloadingReplies: 12Last Post: 16th Aug 2013, 19:01 -
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 22:27 -
ReClock v1.8.7.9 to force every video @ 60fps
By SoberWarlock in forum Software PlayingReplies: 11Last Post: 1st May 2012, 08:50 -
Video shot at 60fps looks like sped-up motion on MAC. Please help
By nastiakru in forum MacReplies: 3Last Post: 18th Jul 2010, 20:45 -
how to convert a subtitle from 25fps to 23.975fps?
By Ankin in forum SubtitleReplies: 2Last Post: 16th Jun 2008, 16:28
