Hello,
I have a problem with Video Mastering Works 5. I used TVMW to encode a file from avi to bluray 25. After the encode the audio is choppy. The video looks fine and has no stuttering and the audio syncs correctly to video, ie words match the movement of peoples mouth. It sounds like there are dropouts every second or less. Like someone hitting the mute button on and off.
The video started as 1280x720P avi, with 2 channel stereo audio 48khz. It was captured using a BlackMagic Intensity Pro. The total file size is 772gb. There are no problems with the audio in the source file.
I chose the default settings in TVMW for a 25gb Bluray disc.
Video: mpeg-4 avc, ntsc, 1280x720, progressive, 59.94 fps
Audio: dolby digital, 48000hz, stereo, 256kbps
Format Type BDMV - MPEG-4 AVC
CBR
Performance Normal
My system is a Intel Core i7 880 @3.07ghz, 8gb Ram, 64bit Windows 7. I use a pair of WD 1tb Velociraptors in RAID0 on 6gbs SATA.
Any ideas on what is causing the audio dropouts?
Thank you.
Results 1 to 1 of 1
TMPGEnc Authoring Works 5 Problem
By KTH in forum Authoring (Blu-ray)Replies: 8Last Post: 11th Aug 2012, 05:01 -
TMPGenc Authoring Works 4 sync problem
By deadmort in forum EditingReplies: 2Last Post: 1st Nov 2011, 06:41 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Problem creating a dvd that works on standalone players from .avi xvid file
By brycej817 in forum Authoring (DVD)Replies: 4Last Post: 17th Apr 2008, 17:50 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 08:57
