ok problem solved and i recommend showing this thread for any other who will ask about greek subs coz i saw many threads about it
Results 31 to 40 of 40
Perhaps you could try to open it in notepad, file -> save as, choose UTF-8 in encoding and press "Save"
found solution alone!! I just saved file in diff ways, finally saved as original in libre office, the original format it gives, and then opened in worldpad and saved as unicoded txt
It is not sufficient to have your computer set to Greek, you need to set other language options when subtitling, in your editor, as well.
I work in subtitle translations and I would recommend for any other language that is not English to be saved in the file you use for subtitled (either srt or txt) with UTF 8 pref. UNICODE encoding. Translation and readability of languages other than English require special ANSI codes, if you choose to go with ANSI encoding, and it is a bit more complicated option.
You can easily do an UTF8/UNICODE encoding by selecting the encoding when you save the file (under the file name field, there is a field for encoding). Using Notepad++ when you write your subtitled makes this apparently easier by pressing a button which gives you all the encoding options. I found it easier to use the simple save as... encoded as.. system.
Proud supporter of free TED subtitling ... blog.talkshub.net -
All these methods are a waste of time.
A very fast, few-click method is to:
use SubtitleEdit > File> Import plain subtitle and manually select encoding> choose Greek/Cyrillic/Arabian Windows, etc.
Then to Translation menu, Translate to language of your choice if necessary.
the greek subtitles do not show at all
By eleeeni in forum Video ConversionReplies: 2Last Post: 26th Jun 2011, 13:52 -
unreadable greek subtitles
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 05:52 -
greek subtitles problem
By ioakim in forum Video ConversionReplies: 1Last Post: 15th Aug 2010, 04:31 -
Problem with GREEK SUBTITLES
By neroman00 in forum Video ConversionReplies: 3Last Post: 29th Dec 2009, 08:48 -
GREEK sUBTITLES HELP.
By AndreasTorous in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 11:07
