Ok here is the problem...
When I convert my NTSC DVD's into mkv the picture judders now I have 2 compressions on my software difference being the kbps speeds...now should I be using the slower one for NTSC and the higher one for PAL?
I do know when going to mpeg I use the correct one for the original DVD and that is easy to see because the software guys have very nicely marked them as such now with the mkv they don't.
Any help on converting would be lovely...only one thing treat me as very stupid as learning as I go along...
Oh I am using AVS at the moment but I do have Nero 10 but find that Nero 10 works when it wants to!
Thanks in advance guys
Kriss
Opps think I put this in the wrong forum...sorry :S
MKV is a container.
https://www.videohelp.com/glossary?M#Matroska,%20MKA,%20MKV,%20MKS
Which video/audio codec(s) are you using? -
Ok now that is a question....I am just about to shut down computer so if you tell me how to find out that info that would be a great help as I say very new to all this stuff...and I will post about it in the morning...
Thank you!
Kriss
Handbrake doesn't directly support interlaced encoding. If you let it encode progressive the file you get may or may not judder or show comb artifacts depending on whether the player is sending the video to an native interlaced output (composite, s-video, interlaced component) and which field order it decides to send it. You can properly encode the video as interlaced with the correct field order to make sure it always plays back properly by manually adding the interlaced flag to the x264 command line:
https://forum.videohelp.com/threads/344902-Detelecine-decomb-issues?p=2151515&viewfull=1#post2151515 -
Well thanks to the first link I have now found out the info I need to know and how to get it easily which was half of the problem....and I am very lucky as AVS does the original frame rate when converting you guys should really have a look at their software all of it is damn good and a damn good one off price as well...
http://www.avs4you.com/index.aspx
Nero is good but for simplicity I do like AVS and all I can say is thank god I have both so I can choose between the two....
Thanks guys for all of your help!
Hugs
Kriss
Problem converting an NTSC video to burn to DVD
By KajDarkwind in forum Newbie / General discussionsReplies: 7Last Post: 6th May 2011, 01:24 -
converting PAL DVD to NTSC while preserving chapters
By andreyvul in forum LinuxReplies: 10Last Post: 2nd Sep 2009, 04:04 -
Converting PAL ISO to NTSC for DVD-Video
By Nate7410 in forum Authoring (DVD)Replies: 1Last Post: 18th Sep 2007, 15:27 -
converting PAL AVIs into NTSC DVD
By exekutive in forum ffmpegX general discussionReplies: 0Last Post: 24th Jun 2007, 19:20 -
Converting an NTSC DVD to PAL w/ DTS
By thisismyname07 in forum Authoring (DVD)Replies: 28Last Post: 27th May 2007, 00:57
