Hi. I recorded the ANZAC Day parade on a Sony PVR (http://www.sony.com.au/product/svr-hdt1000) and wanted to edit it on my computer. I copied it to an external WD 500GB drive but had to format the drive first to suit Sony. Now when I plug the external drive into my Mac it does not recognise the Western Digital (WD) external HDD. The message I get is "the disk you inserted was not readable by this computer".
I would be grateful for any help on how to fix this problem so I can read the file on the WD HDD via USB/firewire and then copy it to my Mac to edit it.
Many thanks, Woodserjimmy.
Knowing SONY it probably is their own encrypted format and not possible to read. PVR's like the Topfield or Beyonwiz record a standard mpeg ts format file easily transferred to a PC or MAC for editing. Not much help now for you other than to suggest you do it old way like transferring VHS to PC ie use a capture device and play the program back in real time. PVR's to avoid are the ones marked "Freeview" they offer nothing but prevent you from transferring files to a PC etc. They also prevent jumping over commercial breaks (fast forward only).
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Thanks for the advice. I'll try playing it from the PVR and then recording it onto another device. A bit of a pain as the parade went for 2.5hrs!
TS-files with missing PCR?
By dagfaune in forum Software PlayingReplies: 18Last Post: 16th Jan 2012, 12:10 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 16:33 -
new recorded dvd can not be played or recorded on after the recording is do
By dlaleh1 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Jan 2010, 23:06 -
Streaming Live Video with a pre-recorded video
By mmanor in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2009, 03:33
