hi help please this old man
i have some videos that a friend gave me back in 1995
of a old tv show that was filmed in queensland, australia
timetrax thay are in .avi format that need to be clean up a bit
i think he got them of the net,thay look like thay were
recored on to vhs tape and then captured to pc as .avi
i have VirtualdubMOD and Avisynth used them a littel bit
a loug time a go.
can some one rite me a Avisynth scripts
show me how so can clean then buy about 50%
i can not find them on dvd
i have up loaderd 3 short videos
vid 1
vid 2HTML Code:http://www.mediafire.com/?g58welyf9p3ibii
vid 3HTML Code:http://www.mediafire.com/?k21vwmpw4g524a5
thanks for any help.HTML Code:http://www.mediafire.com/?zm9917kdpxfrk3l
sys info
Microsoft Windows XP Professional
S Pack 3 Build 2600 x86
cpu Core2Duo E8400 3 gig
ram 2 gig
video card NVIDIA GeForce 9800 GT
Realtek High Definition Audio
PIONEER DVD-RW DVR-111D
hard drives 160 gig + 1 gig
Results 1 to 13 of 13
Bulldog57
Your 1995 time frame might be a bit off. Either that, or something has happened to the original videos since 1995. In 1995 the video content available on the internet was in its infancy -- in any event, mpeg4 video with h.264 compression were not available in 1995.
If they were originally recorded to VHS, then half of the original interlaced video information from those recordings has been removed by deinterlacing and saving in seriously lossy HD compression at half-image size. The original interlaced TV broadcast might have been interlaced 640x480 at 4:3 broadcast ratio, but the video is non-interlaced 352x240 at 2:3 aspect ratio. The audio is 44.1 KHz variable bitrate, which will be a problem in VirtualDub. Even after cleanup (which won't get very far after video has been mutilated to this extent), the best you can get is small frame playback for PC only.
Your PC should be fine, but the 160-GB is going to get filled very quickly. I don't understand the "+ 1 gig" drive size. Is that a mis-type?Last edited by sanlyn; 22nd Mar 2014 at 09:26.
sanlyn
sorry i have 2 harddrives 1st is 160 gb the 2hd is 1tb and i got a 2tb coming this week
and i put roung date i got videos it was about 2009 sorry man
if it can be done with 3 scripts good
if you think its not worth doing it ok
thanks for replyLast edited by Bulldog57; 29th Apr 2012 at 07:31.
Bulldog57 -
Yes, I figured you probably meant 1-tb instead of 1gig.
The best you can do here with these videos is to remove some grain and noise with TemporalDegrain at default values. This is an .avs function, not a .dll plugin, but it requires a number of dependent plugins and functions that might not be worth the trouble of learning and downloading. Simple smoothers or plain-vanilla spatial filters will do little for you here. The main download page that lists requirements is here: http://avisynth.org/mediawiki/Temporal_Degrain
Also, the video appears to have been cropped to get a wide-screen image. That's a no-no, and is not the way it's done, not even for low-bitrate MPEG1/MPG4. The audio is non-standard as well, so there might be sync problems with extended playback times. So you are sort of stuck with small frame playback for PC-only; there is not enough bitrate here for resizing or full screen display, which will simply make the video look worse.Last edited by sanlyn; 22nd Mar 2014 at 09:26.
Since i can see noise patterns i say neat video will be your best friend for the next few days.
I just tried it, if you filter more on the high freqs (where noise is more apparent on the vid1 sample) and none or very low for the mid /low freqs, that should do it.
TheMaster1*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
ok will give neat video a try see how we go cheers for all the help from sanlyn and TheMaster1
Bulldog57 -
Is this it? http://www.imdb.com/title/tt0106154/
and if it is then maybe this is the solution
http://www.dvdbye.com/product_info.php?products_id=37
TIME TRAX - THE COMPLETE TV SERIES ON DVD
Limited Edition DVD Box Set
Every Memorable Episode in One Huge Collection - Lowest Price Online Guaranteed
Darien Lambert, Captain of the Fugitive Retrieval Section in the 22nd century, time-travels to the 20th century to capture 22nd century criminals who have escaped by time-traveling. He is armed with a PPT, a 3-button weapon that can render a man unconscious or send a man to the 22nd century. He has a computer named Selma, disguised as a credit card. Selma helps him to capture the fugitives, for she has access to various databases, and can make logical conclusions. She has also many other functions. The main criminal is Mo Sahmbi, who invented the time machine (TRAX) and helped the criminals to get away. Lambert cannot go to the 22nd century until he has captured all the fugitives.
What an amazing DVD Set for the Time Trax Fan!
All 44 Uncut Episodes - 2 Seasons on 11 DVDS
Excellent video and audio quality
100% in chronological order
Commercial free and unedited
This box set contains all 11 DVDs with Custom Artwork.
These DVDs are region free so they will play on any DVD player Worldwide and DVD-Rom, X-Box or PS2 worldwide.
These are brand new, in stock and ready to ship. On Sale for a Limited Time only.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
neat video is working and im geting back ups of his DVDs cheers
Bulldog57 -
Not necessarily - it could be the source for what he has. 352x240 is a VCD resolution, so legal on DVD too - though a strange choice for a PAL series (usually 352x288). But look at the tiny screen cap on that page - even at 188x131 you can see horrible VHS artefacts!
Cheers,
David. -
Although stranger things have happened, I suppose, I myself have yet to see a retail DVD at VCD resolution. So I was going by the resolution, yes, but also by the fact that what he has has already been deinterlaced. Maybe that was done to the retail DVDs as well. My suggestion is that the OP go get them from his 'mate'. At least then they won't have been further degraded by having been reencoded to h.264 video at too low of a bitrate.
Take a close look at the website though. This isn't a proper retail DVD IMO.
But yes, hopefully it's full res - or at least half res, rather than VCD!
Cheers,
David.
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 8Last Post: 10th Jan 2026, 15:42 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
Vdub Clean up on fuzzy videos transfered to dvd
By Konfusion in forum RestorationReplies: 10Last Post: 16th May 2009, 12:07 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13 -
wiped clean
By aanfield in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2007, 15:12
