  1. Hi
    I have downloaded asfbinwin1.8.2.903.zip, from video help, the author, and many other sources, in every instance the zip contains an older version. I even had someone in britain download it and the results were the same.
    I ask for someone who has asfbinwin version 1.8.2 to put the executable in a zip and email it to me.
    If you will help reply here and I will give you my email address in a PM.
    thanks.
  2. What makes you think the version is older?
    I know there are discrepancies, but the "about" information suggests it's 1.8.2.093.
    Windows properties says 1.8.0.874, but the last version 1.8.1.892 also said that. It' s not uncommon for a programmer to forget to update that information
    The changelog and date modifed suggests it's the correct version when you compare older releases. Also the filesize of the binary is different from previous release. All these suggest it's at least a different version
    Perhaps you could contact the author if you're still concerned, or use the command line version which is updated to 1.8.3
  3. Ok
    I looked at "about" it does say 1.8.2.093
    But its supposed to have a preview? Where is the preview?
  4. Originally Posted by asfbinwin View Post
    Ok
    Push the preview button . You probably just missed it. It's the 4th button down in the middle
  5. Ok
    I got it now.
    Im so smart Im stupid.
    thanks
