Forgive me if this is listed someplace on the site. I did my best to search for what I am looking for.
Converting HD (1920x1080) material to MKV keeping it either 1080 or 720
First off. Is there a chart or maybe someone can just write them down here, that tells you "crop numbers" for specific aspect ratios ?
What would you crop 1:85.1 and 2:35.1 to remove the letterbox lines when dealing with 1080
Second. Does it even matter ? Are those black lines even taking up that much in the end result ?
Results 1 to 12 of 12
1.85:1 video in a 1920x1080 frame: Crop a total of 42 lines off the top and bottom
2.35:1 video in a 1920x1080 frame: Crop a total of 263 lines off the top and bottom
But it's best to leave your height an integer multiple of 16, or at least 8. So leaving 1920x1040 or 1920x816 is better. -
That's why I've never bothered with cropping when I make an MKV. And it's still a compliant resolution if I were to for some reason want to run it through tsMuxer to make a Blu-ray or AVCHD from one.
So the majority do crop then? I just don't see the point when it's such an insignificant amount of space saved.Pull! Bang! Darn! -
So what about dealing with "bugs" in that area ? Much bitrate in that case ?
There are times when it makes sense to crop. For example, when you have a ~16:9 movie letterboxed on a 4:3 DVD. When you watch that video on a 16:9 TV you end up with a small picture surrounded by letterbox and pillarbox bars. If you crop away the black borders you won't have that problem.
I should have been more specific. I was talking about MKVs made from Blu-Ray. I confess I don't watch DVDs much any more. Although when an old favorite is released on Blu-Ray, I buy it.
Yeah, the postage stamp thing, like on some early DVD releases, for example Home Alone. DVDRB could easily take care of that, if you wanted to output as DVD-Video.Pull! Bang! Darn! -
I guess then in some cases it would want to be done but in most cases when all you have are black bars.
Best to just leave them be as they do no harm on output.
A couple questions about Windows Movie Maker. Cropping, custom video...
By Kisai in forum Newbie / General discussionsReplies: 0Last Post: 10th Sep 2011, 21:19 -
VirtualDub questions about cropping and "blurring"
By SignedupGuest in forum Newbie / General discussionsReplies: 17Last Post: 18th Jul 2010, 18:19 -
I need help with cropping!
By UnD3R0aTh in forum DVD RippingReplies: 23Last Post: 23rd Mar 2010, 01:33 -
Cropping...
By bsuska in forum Video ConversionReplies: 40Last Post: 15th Jul 2009, 15:27 -
cropping
By exekutive in forum ffmpegX general discussionReplies: 5Last Post: 25th Aug 2007, 00:02
