Hello
I have one jvc gy-hm 700 and noticed that I destroyed a shot.
plays the 2 seconds after crashes, matter the shot is normally 1 minute.
the card is sandisck 32 gb class 10.
I can not understand what the cause.
if you know someone, let us give an answer.
Thank a lot.
http://www.kiva.org/about -
Good morning. No I have not happen again. Only 2 times before, all she had done was drop frame noise for 1 second and we continued normally after. This time, however, destroyed the clip.
I hope to be the cause of the error handling cameramen, though I do not think 2 times pressing the record button for something to happen.
Also, the clip from the sd card, can not accept either copy past transfers to the pc. Frankly it is very scary what happened. Thank you for your answer and I wish to blame the wrong command. If you have an answer even in the future, please i would like your help. -
hello after a long time.
returns with the same problem (see above).
after so long gave me the same problem. While she was writing normally, with 1920 x 1080, took off my error when I did transfer to pc my hardware.
I have a shot 40 seconds to 30 seconds to play normally on cam n suddenly halts the picture. The problem is that anything not done with copy and past the pc.
In the machine there was absolutely nothing strange during reception. The question is why this happens, he has also written only 250 hours.
This only I can say with certainty is that apolitical and both times I had the same card (sandisck 32 cb class 10) and twice made it into the third shot from the beginning of my work. This might confess that it's the card? or the camera?
Please if someone can help me. THANKS
Dazzle 720x 480 Frame Drop
By genericman in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Mar 2011, 11:37 -
HDV Video >>>>> Use Non drop frame or drop frame and why?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 3rd Nov 2010, 19:30 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 05:22 -
Frame drop in firewire HDV transfer
By Dinu Bandyopadhyay in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 19th Oct 2007, 12:29
