Thank you both I will try this later today. and come back what happend
Results 61 to 64 of 64
You have lots of samples on this forum it is quite simple, I prefer MeGui, because it will encode audio at the same time and mux it all together. If you use command line to encode H.264 with x264 you have to encode audio separately and then mux it together.
CLI is handy if you have a lot of files to encode together with some BAT file, but I do not mind to load it manually. But of course for hundreds of files I would use that.
I use kind combine workflow with HDV video and batch render, because HDV has to be indexed first with DGindex so I use CLI that does that for a bunch of HDV files and creates avs at the same time and then I just load it all into Megui one by one.
I'm sure everybody has its own workflow. -
Damn you have a sick "know how" I also manage to put the soccer-match on the media-server and stream´t it with my xbox in a GOOD quality.. I still prefer my movies ripped with Handbrake "newest" but I have a hard time choosing what CRF level i should use it is normal DVD-rips, the reason for me not using MEgui there is I simple don't know how, and its so easy on Handbrake and quality is awesome "the Queue" is also great.
I went to read a lot about what the XBOX can and cant do, I noticed this:
File extensions: .mp4, .m4v, mp4v, .mov, .avi
Containers: MPEG-4, QuickTime
Video profiles: Baseline, main and high (up to level 4.1)
Video bit rate: 10 Mbps with resolutions of 1920 × 1080 at 30 fps.
Audio profiles: AAC, 2-channel, Low Complexity
Audio max bit rate: No restrictions.
MPEG-4 Part 2 support
The Xbox 360 console supports the following for MPEG-4:
Its not all of the thing only some..
link to the rest: http://www.xboxlife.dk/forum/viewtopic.php?f=54&t=72628
Is there any software ONECLICK or easy that can repair a soccer video like I wanted to in a simpler way, or do I have to script and the whole thing again?
Conversion to stream to Xbox
By blueleo65 in forum Video Streaming DownloadingReplies: 4Last Post: 23rd Jan 2012, 06:43 -
i need this to stream on xbox 360
By carlos28355 in forum Video ConversionReplies: 17Last Post: 1st Jul 2009, 20:18 -
stream HD movie from Pc to Xbox using Tversity - help
By loki1664 in forum Media Center PC / MediaCentersReplies: 2Last Post: 9th Jun 2009, 15:49 -
Stream .iso to my Xbox 360
By nfl2k2 in forum Media Center PC / MediaCentersReplies: 3Last Post: 21st Oct 2008, 18:43 -
Stream MKV to Xbox 360
By spork985 in forum Media Center PC / MediaCentersReplies: 2Last Post: 21st Jun 2008, 07:35
